Scratch Build – In Progress Dark Blade by G69T
Discussion in 'Project Logs' started by G69T, 30 Nov 2004.
  1. anarklov3r
    anarklov3r What's a Dremel?
    30 Apr 2006
    Hey id be careful with that pump...
    Most watercooled rigs will still exceed 35c load temperatures on the cpu... and that pump clearly states MAX 35c...
    sooooo id reccomend finding out what EXACTLY that means :)
  2. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    You definetly need to check up on that, good spot guys :)
  3. Guest-23315
    Guest-23315 Guest
    Metalic sex..........
  4. Nexxo
    23 Oct 2001
    Weird... Another picture of that pump (from an Italian shop site) here does not show a max. temperature rating. So perhaps there is an uprated revision... A close-up picture of G69T's pump here reveals that it has no max. temp warning either. So no worries.
  5. anarklov3r
    30 Apr 2006
  6. yahooadam
    21 Mar 2006
    They look very similar, but there do appear to be some differences, i assume that that is a new model or somthing
  7. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    the differences are power req. and the on on freemodding.it has an addon piece on the front. If you look at G69T's pump, there are grooves where that piece can go. Also the one on freemodding has a max temp of 35C
  8. gometro33
    gometro33 What's a Dremel?
    11 Jan 2005
    And the G69T took the suction cups off.
  9. G69T
    G69T CNC Modder
    6 Jun 2004
    It's a few time I never post anything. That's about I apologize with all you....and I would like to thanks everybody for your interesting.
    About the pumps.
    The pump can be used in fresh water with maximum fluid temperature of 35°C (instructions manual of the pump), but I have testing the system with fluid temperature over 43°C without any problem.
    About the HD support.
    I want to test the noise with the phonometer when I have the 2 HD.
    I'm very very busy at work and I have little free time only for the bicycle (for my body :D)
    Z O O M !
    Bye bye :thumb:
  10. Co2
    Co2 CadUser
    2 Nov 2005
    Just like the 'penny+item measurement' :)
    Just needs a toothpick to show exactly how big it is ;)
  11. Germonicus
    Germonicus What's a Dremel?
    7 Jun 2006
    Looking wonderful so far. You keep making me think "oh,that last mod doesn't fit in" but then you add something else and it balances everything out again :)
    To all the "mod purists" who are complaining that this is bad because you're using CNC and bigass machines: where does using the right tool for the job start/end? If you take the analogy about using only hobbyist tools to another level you'd have people saying a dremel is wrong as you should only use hand tools.....next step would be people bragging that they modded their case with bare hands :D
    A little late for suggestions I suppose,but here goes:
    Could you possibly make the corner blades extend above the top of the case to aid looks (sorry but they seem a little "stubby" atm).
    And a final question: How does the res work for extended periods? Any worry about cavitation/water hammer noise being generated by the aqua blades?
    Regards,Germ
  12. Silver Spoon
    Silver Spoon What's a Dremel?
    12 May 2006
    Nice bike. I want one.
  13. saab
    saab What's a Dremel?
    28 Nov 2005
    Amazing project!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    Keep Up the Great Work !!!!!
  14. J Swan
    J Swan What's a Dremel?
    14 Mar 2005
    Mr G69T
    Since you have started you amazing project, I have change my job, sold my flat move into a little house, found a fantastic girlfriend.
    Every day i log on waiting for you just to change a little thing……..
    What’s happened have you gone on strike ?
    Have we your fans done anything wrong ?
    Are you scared of BaDassumption ?
    Need a update of any kind even if its on, tour da france ?
    Looking forward to your future installments …
    J swan
  15. ỒĊBłůē
    ỒĊBłůē Also available in black
    2 Mar 2005
    Maybe the guy has his own life to lead?
    Perfection takes time, and some worklogs take much longer than this.
    He'll update when he's ready, and I don't think dutch (BaDassumption) sees this as a contest.
  16. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I love machining. That is a company shop you don't own that place do you?
  17. thriteenthmonkey
    thriteenthmonkey What's a Dremel?
    19 Jan 2006
    yeah, he works there
    he would have to be so loaded to own a place like that
  18. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    never seen a bike with so few spokes before!
  19. hydro_electric_655
    13 Jul 2006
    I wish I was loaded I would sleep in there. :eek:
  20. odinnn
    odinnn What's a Dremel?
    19 Jul 2006
    Love your work, but please get a real bike :hehe:
