Darkness RedLi
Discussion in 'Project Logs' started by P.P InDaHouse, 18 Mar 2007.
  1. P.P InDaHouse
    P.P InDaHouse What's a Dremel?
    30 Jan 2007
    Beginning: 16-03-07
    End: for finishing
    Before everything, sorry for my bad english :rolleyes:
    Hi all
    I'm here to present you my new project. The case i will use it's
    a Lian-li PC7b. All the project will be realized on one of my CNCs.
    I already bought the case 2 mounths ago but until today the CNC
    was busy with modding and waterblocks projects for my clients.
    The name of projecto says everything, the subjets will be the black
    and the red colors. However in these 2 months after the acquisition
    of the case I was thinking about the project, having some ideas and making some sketechs.
    The photos are taken off by cellphone, then the quality isn't very good
    When the project will be finished the case will go to a photographic
    session.
    The case as already almost know is this
    Then now I present you some sketchs that I've made.
    As it will be the frontal
    Red acrylic and aluminium.
    The pieces in acrylic in the 5.25 bays will exist in the 3.5 bays
    but in proporcional size to that bays.
    Now the sketch of the left side panel
    As already you must have repaired the mesh that I will apply in the side panel will be red painted.
    The right side panel (can be modified)
    And now a general view
    Tomorrow I will put some photos.
    Regards
    P.P InDaHouse
  2. Stubkier
    Stubkier What's a Dremel?
    23 Nov 2005
    Looks great, black and red is just goes good together.
    But personaly I donøt think the window in the right side fits the rest of the case - stick to the stright lines.
    Stubkier
  3. P.P InDaHouse
    30 Jan 2007
    im gonna make other sketch to the right side panel
  4. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    Yeah i dont like the right panel either...
  5. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Is there really a need for 3 external 3.5'' drive bays? Seems kind of a waste of intake space on the front.
    Make the top section shorter, and make a bigger intake down the bottom.
  6. DAE_JA_VOO
    11 Nov 2005
    I dont understand something. You have only 2 3.5" bays on the case, but 3 in your design :|
  7. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Yeah the design is incompatible with the case front.
  8. DougEdey
    5 Jul 2005
    There is an internal 3.5" bay. By the looks of it a new case front will be fabricated because the existing fan is a 120mm but the design has 2x80mm.
  9. P.P InDaHouse
    30 Jan 2007
    @ DAE_JA_VOO and Duste
    this case isn't the lianli pc7, but its almost equal
  10. Duste
    1 Oct 2006
    I never said anything about the case being anything, just stating that there's really no point for 3 external 3.5'' drive bays. Hell, I wouldn't even bother with 2 to be honest.
    As I said, I'd suggest sticking with one or two external 3.5'' drive bays and giving yourself a better intake.
  11. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    The computer you're using to do the Sketch-Up models with is the PC-61. The PC-61 has two 80 mm fans up front, one 80 mm blowhole, and one 80 mm fan in the IO panel. The PC-7 is the same as the PC-61 but with one less 3.5" bay and instead of four 80 mm fans, it has three 120s. Just a slight revision Lian-Li made when 120 mm fans became really popular. Aside from that, they're essentially the same case.
  12. P.P InDaHouse
    30 Jan 2007
    Update 1
    Here is new photos
    Today i started the left side panel cuts
    CNC Power :rock:
    I bought yesterday all metal polish. This is just an experience, I will polish this better.
    So here is what I do today
    hdd cage disc before
    and after...
    Today you will see the left side panel cuts ready, stay tuned
    Regards
    P.P InDaHouse
  13. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    I love lian li and when somebody have a brand new idea for that case. Very very nice.
  14. P.P InDaHouse
    30 Jan 2007
    Update 2
    Hi all
    Left side panel ready :D
    I need to buy acrylic, maybe tomorrow.
    Comments please :D
    Regards
    P.P InDaHouse
  15. Ediejo
    31 Jul 2005
    cnc power rulez. :rock:
  16. P.P InDaHouse
    30 Jan 2007
    Update 3
    Hi all
    Here is some new photos of the cuts with more details
    The curves of the biggest window with 10mm ray
    The 3 windows (all equal ones) with 25mm ray
    The slop already know of Lian-Li with 45 degrees of inclination
    And to finish, the left side panel mounted in the case
    Now im making new sketchs for the top and for the right side panel...
    Regards
    P.P InDaHouse
  17. Ediejo
    31 Jul 2005
    Very nice start from the mod. I love the side panel.
  18. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Looking good, those kind of cuts can be made by hand, but damn it's easier to do with a CNC :hehe:
    With red acrylic behind that thing, it's going to look really sweet.
    Keep going, the audience is watching :D
    Janne
  19. P.P InDaHouse
    30 Jan 2007
    thanks all...
    with that comments i've more inspiration to my project :D
    I can say now that i will use watercooling with waterblocks and reservoirs made by me.
    I've many ideas but the watercooling need to wait, the case is first.
    Thanks all :clap:
  20. P.P InDaHouse
    30 Jan 2007
    Update 4
    Hi again guys, are you liking my project? Sorry abou the pictures, i will buy
    a camera soon :)
    I've some news
    Yesterday I bought red acrylic, but I will need more. I will use acrylic on the front,
    to make some grillz and to make new PSU plate.
    now some photos of the acrylic
    The red acrylic is very beauty and combine with the aluminium black anodized
    And a little work that I did yesterday
    A piece of mesh
    and then
    Its all right, now i will make the new PSU plate with Black mirrored acrylic.
    Hope you like
    Regards
    P.P InDaHouse
