DarkWater SpaceShip - First Prize winner!!
Discussion in 'Project Logs' started by Kumo, 10 May 2005.
  1. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Hi.
    Here my new project. After the Lan Machine Interface i made some works (soon you'll see the pics of the most important before this) this is the last.
    I started this Log in the Mashie.org forum, so this first post is a bit long to run a little :)
    As the title says it will be a watercooled Shuttle. Still i need to decide some details, but here we go with the pics:
    Some useless stuff
    First cuts: The front. Later was needed to cut a little more.
    First cuts: Rear. Pass throught for the tubing and rad. Of course, the fan grill also blew up XD
    The BLIM. Unfortunately isn`t the custom fittings version. Is for 3/8".
    The duct for the rad. An old PSU fan adapted and black painted.
    The pump: Swiftech mcp350 or Danger Den DCC or... Anyway enought small for the shuttle.
    Testing the VGA WB. It`s a homemade wb for the AGP 6600GT. Made by P0stman (Spanish homemade WB maker) and sightly modded and painted by me. I don`t know if there is any block for this special GPU like the NV68
    As you can see, the WB is too thick so i need to create "something" in the hull to acomodate all.
    Complementary works:
    Routing the eject button and LED to a new position. The connectr makes easy remove the DVDRW if needed.
    Half finished main chasis. Still need some work more.
    The colors for the theme will be black, silver/chrome and white lightning.
    If you know my others works... yeah, I like black coloured PCs...
    The front panel works. I`m thinking in remake some details... Or the whole piece, so feel free to comment. (actually i've retouched the buttons sections)
    The new plexy cover. Opening for the DVDRW tray and vents for the HD.
    The new cover with the cutted front bezel and the dismantled LIS 2P.
    Markings for the control buttons (eject, reset, lights...)
    The idea with the chrome buttons. After i decided to change this concept a llittle
    The back of the plexy before painting. The rectangular shape is to avoid cover the LIS "screen". The hole in the middle is for the power key switch.
    Painted front parts.
    Some test...
  2. Kumo
    18 Oct 2004
    Blackwater, blackwater.... mmm... Darkwater?? What do you think about that name? Is an idea of the great Mashie
    Finally i`m not going to use that (was a bracket for the buttons). For the front piece a needed a diferent approach. An asimetrical approach.
    Four buttons in a pad style, with the leds between in one side (in the second side... you`ll see it later). This is the piece i maked to hold them, outside the front.
    Araldit epoxy gluing/welding. Tomorrow will see it looks. As you can see, also i reduced the size of the LIS screen to only the text area. Then i`ll put a dark tinted filter behind if is posible.
    While the front is drying, i sleeved a little the PSU wires. As i can`t sleeve the SATA wires, i tie zipped it a lot.
    The half painted drive cage and pump bracket. One level gone and the rest was welded with Araldit epoxy.
    The pump location. Upside down when instaled.
    This is the finished cage.
    The akasa pax mate serves to reduce noise and vibration from the pump and aids to block, sightly, EMI to the HD.
    Yesterday arrived the Brass TDX:
    It looks impressive.
    Wiring the bright white LEDs for the underlight (AKA Landing Lights if all goes well...)
    That was the works until today. More to come... maybe this evening. Feel free to comment.
  3. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    You should definatily try black tubing.
    Look at Modsquad's mod 'Black Narcissus', he has a relatively black/dark theme with lots of red background LED's.
    Just my 2 cts. :idea:
    The Waterblock colors on the Vidcard together with the pcb color and most heatsinks make up a nice blue/silverish scheme? Was that on purpose? Looks great?
  4. Kumo
    18 Oct 2004
    I know it. Black tubing will be fine, but is rather difficult to find here. Maybe with dark blue dye or something similar. At least for now, the hull not going to be windowed so, you can´t see the inner parts.
    I have another block from P0stman, for the chipset, and also i've painted it in that metallic blue from Duplicolor. And in my last rig i had the Zalman WB so to continue with the color patern i've painted this in blue. In add, it match with the zalman HSinks and the PCB. Since i've moved to this project, maybe, black color paint would be better...
  5. netzerling
    netzerling What's a Dremel?
    25 Jan 2005
    [Spanish mode: on]
    Mola ver buenos trabajos españoles por el extranjero, sigue asi, gran trabajo
    [Spanish mode: off]
    Very nice work, as always. :naughty:
  6. Kumo
    18 Oct 2004
    [Spanish mode: on]
    No sera el unico mio que veas por aqui :) Gracias
    [Spanish mode: off]
    THX for the comments. You'll see more of that.
  7. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    nice, i love watercooled shuttles.
  8. vapb400
    vapb400 What's a Dremel?
    24 Feb 2005
    i actually have an intense desire for that stock heatpipe cooler, think you could sell it? send me a pm please if you are interested. Thanks.
  9. kaotic504
    20 Jul 2004
    black vinyl tubing is pretty easy to find in the US. they sell a lot of it at HomeDepot, if you really want it. i can buy it for you and ship it over there if you cover the full actual cost. i thought about it but then i thought about how i wouldn't be able to see through it for airbubbles.
  10. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    nic project. If its going to be 1/2 as good as your older project this is going to rock.
    Mod on. :rock:
  11. morishani
    morishani What's a Dremel?
    29 May 2004
    Good work man :)
  12. Kumo
    18 Oct 2004
    @Kaotic504: I'll think about black tubing THX
    @Vapb400: In the beginning, no problem to sell the cooler.
    Today little update.
    I`ve discovered that i have to move the pump 1cm to one side to avoid it blocks the PSU. But is a minor problem.
    Back to the front. Remember we leave it drying?
    This how it looks now. Now the second panel is drying. And as you can see the first one has buttons. To reach that point...
    ...i`ve started with this: The rest of a chrome button. This type of switch is ON/OFF type. So to convert it to momentary switch (for eject i.e.) i dismantled one or two. The plastic is prety weak so i broke one. This gave an idea to cover the fan controler button to match the others in the mod.
    This the dismantled switch.
    The last step is to cut a little, the "pushin bar" to acomodate the cover of the switch. Then only rest to glue the frame of the button hiding the nut.
    When dry i`ll take more pics.
  13. Rh1n0x
    15 Nov 2004
    ¡Éste es su primer poste aquí y usted lo pone en español! ¡vergüenza!
    Too bad about that one button, you hopefully have a replacement part?
  14. Kumo
    18 Oct 2004
    Today i'll buy a new one, but isn't necessary at all (if i don't put more lights maybe...) because i'm going to use the parts to cover the fan switch. I'll make more pics to show you how it looks behind the front.
  15. netzerling
    25 Jan 2005
    Sorry :sigh:
  16. Kumo
    18 Oct 2004
    @Netzerling: I think he was joking...
    XD
  17. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Darkwater:)
  18. Rh1n0x
    15 Nov 2004
    @Netzerling,
    Sorry man! it was a joke.. I was in a sarcastic mood :p
    Speak Spanish whenever it makes sense hombre. :thumb:
    The Title: Darkwater makes me think of something in particular..
    And now i've found it: http://www.imdb.com/title/tt0382628/
    I just knew it crossed my mind somewhere :duh:
  19. Kumo
    18 Oct 2004
    Yes, i love japanese cinema (but not its remakes from hollywood... -_-U) and this in particular is very scary, with simple FX and script.
  20. netzerling
    25 Jan 2005
    @Rh1n0x: It doesn't matter, that's what i was thinking....
    Kumo: Keep on moddin' bro¡
