Case Mod - In Progress DarthBeavis: Queen of Blades
Discussion in 'Project Logs' started by DarthBeavis, 15 Mar 2012.
  1. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    Honestly, I am now motivated to get this puppy done because of the other two talented modders here with StarCraft 2 projects. I will be visiting HuskyStarCraft next weekend and will show him their projects!
  2. Siskods9
    Siskods9 What's a Dremel?
    16 Aug 2012
    Incredible stuff DarthBeavis.
  3. DarthBeavis
    29 Aug 2008
    Testing the acrylic hard lines. This is my first effort so please be kind with the criticism. Also have the line in and out of the loop with regular tubing and fittings (going to take the rig on the mobo tray to a LAN party in a week connected to an external radiator/pump system - sort of an extended proof of concept and also testing out the hardware).
  4. Guest-23315
    Guest-23315 Guest
    Look like a couple slight kinks there Darth, are they bad in real life?
    And any reason for this over tube bar the looks department?
  5. Guest-23315
    Guest-23315 Guest
  6. DarthBeavis
    29 Aug 2008
    just want something different. I have until Feb to get this bending down pat.
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I dont know what to say about the pipes, they looks warped at some times and they are not alligned that well either, you can do better mate :D
    I hope that the next time you will be a pro at this!
  8. ziza
    ziza What's a Dremel?
    21 Dec 2010
    Those acrylic tubes look great, do you had any leaks?
    Those pipes always makes me wonder if during time they do not suffer from small leaks.
  9. DarthBeavis
    29 Aug 2008
    no leaks yet. The next effort I will try lower heat and also will make a buck for bending.
  10. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    DB,use silicone fuel line matching the ID of the pipe,stick 4 or 5" of it in the middle of your chosen bend spot then make your bend.
    The tube stops the pipes collapsing,when its cool,pull the tube out.
    I found this pic as a good example
  11. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    That... is genius.
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Gorgeous build & crazy awesome system. :jawdrop::D:thumb:
    Keen to see the end result. :)
  13. Concrete-Coffin
    Concrete-Coffin Minimodder
    5 Apr 2010
    WOW:jawdrop: need some tissues haha absolutely great work cant wait to see this beast finished:D
  14. Johnny71
    Johnny71 What's a Dremel?
    6 Jun 2012
    So awesome work! :D Keep it up and really looking forward to see it finished, glad I can motivate you, you do the same to me. And really appreciate that you showed Husky it :D How did it go? :)
    Gogo keep it up ! :)
  15. DarthBeavis
    29 Aug 2008
    yes the existing tubing runs are ghetto but they were quickly done meant only to run through PAX East (NVIDIA had me put in Titans for the show).
    I am swapping out all the tubing and fittings for Primochill acrylic hard-lines (blue) and fittings (chrome)
    Installing EK CSQ blocks on EVGA 780s.
    Need to make an SLI bridge cover and wire management stuff with my 3d printer as well.
  16. KoSoVaR^
    19 Dec 2010
    Holy F**K :D!
    Dat power <3
  17. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    780 over kill :)
    Can it play crysis ??? :) WEll i think u can play crisis in 4k and 4 monitors :)
    Not bad at all i like :)
  18. LegendaryScott
    LegendaryScott Trying to live up to the name
    5 Apr 2013
    'Holy F**k' indeed.
    Wish i could run 4 of those bad boys
  19. DarthBeavis
    29 Aug 2008
    damn, looks like 4-way SLI might not be supported still looking into it
  20. Trance
    Trance Two steps forward, one step back
    6 May 2009
    Looking great! Well you know if it isn't supported you could always give 1 to me... :p
