Windows .DAT to .MP3 converter?
Discussion in 'Software' started by j`w0n, 7 Jan 2003.
  1. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    Anyone know of one because while most of my mp3s were dling in kazaa, I paused them and moved em to another folder. Now they're stuck as .dat files and its making me mad.
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    With MPEG based files, you should just be able to rename them and they'll work fine. Obviously if they aren't completed, they won't be the entire song.
    It's always worked for me before.
    Can't hurt to try . . If it doesn't, just rename it back :D
    Hope it helps.
  3. riggs
    riggs ^_^
    22 Jul 2002
    spot on ^
    you can just rename em
    if you can't see the extension of the file, goto 'Tools' -> 'Folder Options', then click the 'View' tab, and uncheck 'Hide Extensions for Know File Types' (this is for XP, not sure of earlier version of windows...)
  4. corvette
    corvette What's a Dremel?
    27 Nov 2001
    u dont even need to do that just right click open with and choose the program u wanna play them with
  5. j`w0n
    17 Jul 2002
    Yeah I know but I was just wonderin. I just moved the files and they changed to the normal mp3 format.
