Electronics dc-ac convertor for invetor
Discussion in 'Modding' started by daguuy, 5 May 2006.
  1. daguuy
    daguuy I hate lolcats
    18 Jul 2005
    i have an old scanner CCFL tube without an invertor and would like to make one for it. the problem is that i'm on a $0 budget and must find all i need laying around. i know how to make an invertor with a center-tapped transformer but i don't know how to identify a center-tapped transformer. i did find a simple one with just 4 pins that i know how to hook up and stuff. so now the problem is i need to find a way to get AC current from a DC source. i've tried thinking of various ways to do that but can't quite come up with a schematic that looks like it'll work. one of them involves an oscillator. the lowest frequency oscillator i can find is 3.4mhz. would a transformer operate at such a high frequency? and does anybody have a shematic for an invertor that uses a simple non-center tapped transformer? i googled but couldn't find what i'm looking for.
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Maybe something like this would work for converting to a higher voltage. If you do not have a 555 IC timer, you can utilize transistors.
    As for running a CCFL, I thought they needed a certain frequency range to work -- 35 - 75 Khz?
    Generally speaking, the higher the frequency, the smaller you can make your transformer due to increased efficiency for a given application. The frequency that your transformer will work at will depend on how it is winded and the material it is made up of. Here you go
  3. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    I know you said $0 budget, but these things can be had for pretty cheap... Odds are that you won't find a coil or transformer of the proper specs unless you wind your own.
  4. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    I hate to say it, but it would be cheaper and easier to get another old scanenr with a working invertor, you might then be able to put higher power transistors on it and power both ccfls.
  5. daguuy
    18 Jul 2005
    well i got an invertor for it and that works but i still have the CCFL tube from a little LCD screen (replaced w/ LEDs for efficiency) and need to make an invertor for it becasue it's invertor is built into the LCD's PCB and i'm not gonna screw that up. i found this simple invertor and figured that the current goes constantly into the middle pin on the transformer and the 2 grounds on the outsides alternate on/off so i fiddled around with it to make it work with a non-center tapped transformer and came up with this. would that work? would i need to replace R3 and R4 with half the resistance?
