Case Mod - In Progress DC Cyborg - Raidmax Sigma
Discussion in 'Project Logs' started by pccrazy, 25 Aug 2017.
  1. pccrazy
    pccrazy New Member
    8 May 2017
    Hi everyone,
    Since this project is in collaboration with TeamGroupInc. going to post the work log here as well. Basically, my last case mod was based on Sinestro (Yellow Lantern) and got an idea to continue on the superhero level. Because I got the Raidmax Sigma case, got an idea based on DC character Cyborg to go with him. And that is where I got the name and everything else.
    And since I did it last time with a action figure, decided to go with Pop! figurine this time. :)
    Here are the current specs and I will add the water cooling parts as I order them:
    Build components:
    MSI B250 Gaming Pro Carbon
    Intel Core i5-7600
    MSI GeForce GTX 1070 Armor OC
    2x 8GB TeamGroupInc. Dark Gaming DDR4 3000MHz
    SiliconPower S55 Slim 240GB
    Raidmax Vampire Series 800W
    Raidmax Sigma
    2x Phanteks 140mm
    3x 120mm ??
    Custom cables: ???
    LED lights: ??
    Water cooling parts:
    Raijintek CWB-C1 - CPU Water Block
    Raijintek RAI-PM5 Pump
    Raijintek RAI-R10 10cm Reservoir
    8x EK-HD Adapter 10/12mm - Nickel
    4x EK-AF Angled 90° G1/4 Nickel
    1x EK-AF Y-Splitter Rotary 2F-1M G1/4 - Nickel
    1x EK-CSQ Plug G1/4 (for EK-Badge) - Nickel
    EK-CoolStream SE 240 (slim dual)
    EK-HD Tube 10/12 500mm
    EK-CryoFuel Blood Red Concentrate 100mL​
  2. pccrazy
    pccrazy New Member
    8 May 2017
    Pictures of the components:
    IMG_3410.JPG IMG_3429.JPG IMG_3432.JPG IMG_3442.JPG IMG_3446.JPG IMG_3452.JPG IMG_3454.JPG
  3. pccrazy
    pccrazy New Member
    8 May 2017
    More pics:
  4. pccrazy
    pccrazy New Member
    8 May 2017
    Some update on some of the water cooling parts:
    IMG_3556.JPG IMG_3557.JPG IMG_3558.JPG IMG_3559.JPG IMG_3560.JPG IMG_3561.JPG IMG_3562.JPG IMG_3563.JPG IMG_3564.JPG IMG_3565.JPG
  5. pccrazy
    pccrazy New Member
    8 May 2017
  6. pccrazy
    pccrazy New Member
    8 May 2017
    I didn't take any pictures of the case (my bad), but I did take these photos [​IMG]
    Some new legs for the build:
    Plates for the top and front cover:
    New cut on the original power supply shroud:
  7. pccrazy
    pccrazy New Member
    8 May 2017
    Prime color sprayed on all parts:
    IMG_7163.JPG IMG_7165.JPG IMG_7166.JPG IMG_7187.JPG IMG_7188.JPG IMG_7189.JPG IMG_7191.JPG IMG_7192.JPG
  8. pccrazy
    pccrazy New Member
    8 May 2017
    Custom plates and the rest colored parts have arrived yesterday. I just placed them on the front and top case cover to see how it will look. Here are some photos:
    IMG_3584.JPG IMG_3585.JPG IMG_3586.JPG IMG_3587.JPG IMG_3588.JPG IMG_3589.JPG IMG_3590.JPG IMG_3591.JPG IMG_3592.JPG IMG_3593.JPG
  9. pccrazy
    pccrazy New Member
    8 May 2017
    So I have been working in my garage for the past two days to do all the cuts and paint works, so here are some photos I took. On the other hand, there is loads of video fotage, so I will include some in the timelapse video if I can post it here at all. [​IMG] Have to check the rules.
    The reservoir from Raijintek was gold colored so I had to fix that somehow and went with carbon sticker to match the motherboard:
    And just a small sneak peek how the GPU will be mounted. Loads of stuff is missing so don't judge the photo. [​IMG] I had to see how it looks.
  10. pccrazy
    pccrazy New Member
    8 May 2017
    Some updates again, but have to do minor fixes to some parts. Nothing too much. :)
    IMG_7459.JPG IMG_7460.JPG IMG_7461.JPG IMG_7462.JPG IMG_7463.JPG IMG_7464.JPG
  11. pccrazy
    pccrazy New Member
    8 May 2017
    And it is done! I'll make a timelapse video shortly, probably show you guys tomorrow.
    Things I did:
    - custom two panels for the case (top and front)
    - cuts on the power supply shroud for the PCI riser and for the pump to fit
    - vertical custom mount (cut out in the case) for the graphic card
    - custom paint on the custom panels, meshed parts on top and front of the case, and power supply shroud
    - placed the SSD on front of the power supply shroud
    - changed the front LED so the Raidmax logo can light up red instead of blue
    - changed two LEDs on the power supply shroud from blue to red
    - carbon sticker on the reservoir to hide some gold parts and to fit the motherboard looks
    All in all, personally, I am satisfied because I didn't want to go overboard with the build and mods. Simple stuff to get the look of Cyborg from the outside and the red interior of the build for his "mechanism" and stuff. [​IMG]
    Hope you like it guys. ;)
    IMG_3669.JPG IMG_3670.JPG IMG_3672.JPG IMG_3673.JPG IMG_3674.JPG IMG_3675.JPG IMG_3676.JPG IMG_3677.JPG IMG_3678.JPG IMG_3679 (1).JPG
  12. pccrazy
    pccrazy New Member
    8 May 2017
    As I said, I will post the timelapse video. Now I am not asking for any subs or thumbs up, it is here if you only want to watch it. [​IMG]
    If it is against the community rules I will gladly remove it. [​IMG]
    Just to keep it short, here is the link:
