Memory DDDR3-1600 11-11-11 is worse than 1333 9-9-9, right?
Discussion in 'Hardware' started by Chicken76, 10 Nov 2012.
  1. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    If it were 10-10-10 for the 1600 module, it would be marginally faster, but at CL11 it is actually slower, right?
  2. GeorgeStorm
    16 Dec 2008
    Depends on the application I think, some programs prefer the speed, others the tighter timings.
  3. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    I would recommend taking a look at the first page of this AnandTech article which pretty comprehensively outlines the workings and quirks of DDR3 memory.
    The part which is most pertinent to you, I have added below.
    Chicken76 likes this.
  4. Chicken76
    10 Nov 2009
    Thanks Kodongo. Have forgotten about that article.
    It seems 1333 9-9-9 is better than 1600 11-11-11 in every regard.
  5. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
  6. Deders
    Deders Modder
    14 Nov 2010
    In terms of actual latency there isn't much in it:
    9/1333 = 0.006751
    11/1600 = 0.006875
  7. adam_bagpuss
    24 Apr 2009
    in real world speed is better than timings nowadays, however anything 1600mhz is wasted unless you have an amd setup using the on board gpu
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  9. Pookeyhead
    30 Jan 2004
    When I was playing around with Geekbench last year, I found that 2133MHz with 10-11-10 1T was measurably faster than 1800MHz with 9-9-9 1T. So reality and paper calculations didn't quite match up for me.
  10. Deders
    Deders Modder
    14 Nov 2010
    It will be faster. it's just that as the mhz increases, the timings don't need to be as tight to get the same latency. So you get the benefit of increased bandwidth without losing out so much in terms of latency:
    10/2133 = 0.00469
    9 / 1800 = 0.005
    So the higher clocked ram actually has less latency even though the timings look looser.
  11. Pookeyhead
    30 Jan 2004
    Well... I got the same numbers on paper, which led me to think they would perform similarly. That .00031 must make more of a difference than I thought.
  12. Deders
    Deders Modder
    14 Nov 2010
    It was probably the extra 333MHz Bandwidth that made the most difference, it's just that the extra .00031 didn't make the latency any less than before.
  13. Pookeyhead
    30 Jan 2004
    Hmm.. yeah.. You're right me thinks. Interesting stuff!
  14. mm vr
    18 Nov 2007
    ...and real world performance, particularly in games, is not affected at all by RAM settings as the article I posted shows.
