Yea i read some of the article at Anandtech.. pretty kool that DDR2 will be on pc's soon.. or later.. and i saw the Windows XP 64 preview..sad performance when it comes to games....
You're talking about an Os that was designed for 32bit, is a preview and is one of the first desktop edns deisgned for 64bit. Tall order dont you think?
ok yea i forget drivers. Iirc Via have only released beta 64bit drivers for their mobos, intel more than likely have some out.. dunno bout the rest. As with all first gen stuff - optimisation comes later.
?? i thought DDR2 had more pins? Looks the same to me or are they just using a photochopped image on a normal dimm?
DDR2 can't be *that* close at least has to wait until intel get their FSB1200 chips out there sure you could use it as overclocking memory on current intel platforms but most motherboards hit a ceiling well before DDR800 that is the first thing i thought when i saw the corsair pic as well, photochopped, the "label" looks more like a graphic, too clear compared to the rest of the photo corsair really doesnt have any specifications on their site at all, a bunch of pages with just waffle but no numbers or anything
You will be waiting a while then, even a transition to 1066 isn't planned till next year DDR-2 will be supported by the upcoming Intel chipsets Alderwood and Grantsdale and will run the memory synchronously for DDR2-400 and DDR2-800 and asynchronously for DDR2-533 and DDR2-667. Of course DDR2 will initially be launched with 200-266MHz clock speeds (DDR2-400 and DDR2-533), rising to 333MHz and 400MHz. Via, SIS and nVidia are all likely to release chipsets with support this year. If anyone is confused about numbers here is a brief guide. DDR2-400 Clock: 200MHz Module known as PC2-3200 (3.2GB/s) DDR2-533 Clock: 266MHz Module known as PC2-4300 (4.3GB/s) DDR2-667 Clock: 333MHz Module known as PC2-5400 (5.4GB/s) DDR2-800 Clock: 400MHz Module known as PC2-6400 (6.4GB/s)
what sorts of latencies would DDR2 modules run at? if the DDR500 range would be the lower end of the scale then would they be the ones that would run at relatively tight timings compared to the cas2.5/3 of now
