Memory DDR3 Channels
Discussion in 'Hardware' started by Omnituens, 9 Nov 2012.
  1. Omnituens
    Omnituens New Member
    5 Apr 2006
    Right, I've been asked this many times and when I look it up I get conflicting information.
    If you have a motherboard that supports Tri-Channel RAM (Socket 1366) and you buy 2 sets of 2 sticks of dual channel RAM and use 3 of the sticks... what happens?
    When I tried it a long time ago the board wasn't happy, but looking back on it the ram itself might not have liked it or been dodgy.
    I see a few outcomes:
    1) The channels listed on the packages are just what they are intended for and will work in a tri-channel setup in tri-channel mode
    2) the sticks will run in single channel mode
    3) system will throw a hissy fit
    4) it will be like pouring coke into a pepsi bottle and the universe will end.
    Anyone know for certain? What with Intel abandoning the 1366 and Tri channel RAM it's getting harder and harder to find.
  2. adam_bagpuss
    24 Apr 2009
    any RAM is fine just buy matched timings and Voltage.
    The reason is #1)
    If the RAM is the same timings and voltage it will be fine. same model/make is preferred to avoid the 1/1000 chance it refuses to work but you should be ok.
    you can use different timings and speeds but it will run at the lowest sticks speed overall.
  3. Taniniver
    Taniniver New Member
    24 Aug 2010
    The only difference between buying an actual tri-channel kit as opposed to some other is that it comes with a guarantee from the manufacturer that those DIMMS have been tested together and will work in a tri-channel setup. The actual DIMMS are identical to any others you would buy, there is nothing special about them that enables them to work as tri-channel.
    As adam_bagpuss says though you must have been very unlucky to have it not work previously.
  4. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    As said before you must have been very unlucky.
    I recently had one stick of ram go in my 1366 setup. I bought a pair of the same kind of ram and used one of these sticks to bring it back up to 3. Everything works fine and I now have a spare stick, should another go in the future.
  5. GeorgeK
    18 Sep 2010
    Completely off topic but this made me think of all the "oh cr*p, did you just divide by zero" pics out there:
  6. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    i have run allsorts of ram combinations on my 1366, never had a problem.
