Ddr4 settings3200 non xmp advice
Discussion in 'Hardware' started by Thewelder, 6 Dec 2018.
  1. Thewelder
    Thewelder Member
    27 Nov 2018
    Hello all,
    Xmp profiles 1 and 2 are not good.
    Was wondering if someone could list basic,STABLE,timings,and the needed mobo ddr voltages(vsso,io,etc) besides the standered ram stick voltage 1.35 for 3200 speeds.nothing crazy,just stable please.
    My specs for ram are Kingston predetor 3300mhz 32 gig kit(2x16 sticks).other specs in my sig.
    Ty
  2. adidan
    25 Mar 2009
    It looks like the F6 November BIOS may help with stability, looks like it's not an unheard of issue.
    May be worth giving it a shot if you haven't already. Otherwise i'm sure there must be some Z390 owners around here.
  3. RedFlames
    23 Apr 2009
    was about to suggest the Ryzen DRAM calculator widget, then notice you're on z390...
  4. TheMadDutchDude
    23 Aug 2013
    What kind of SA/IO voltages are you running? Those could be a big indicator here.
    Is it just unstable or failing to POST (train the modules) entirely?
  5. Thewelder
    Thewelder Member
    27 Nov 2018
    @adidan ,
    I tried f5,f6,f7a...no good...well xmp in general is kinda generic which I understand I suppose.
    @TheMadDutchDude
    "What kind of SA/IO voltages are you running?" -auto
    The sticks do post xmp no problem profile 1 or 2...then after maybe after 1hr or 8 hrs later,blk ops will freeze...tho the pc itself does not...I can hit cntrl/alt/dlt and close the game and continue doing any task again,that's odd in itself usually ram will lock up the whole pc.
    I dunno....my temp's cpu/gpu are ice cold.
    I need a baseline (manual) non xmp loose timings for 3200 speeds (generic and stable)and voltage for multiple ram bios settings if possible please then I can go foward.
    Ty.
    ××××my power supply voltages are all healthy×××
  6. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    If your game is crashing but the system isn't locking up, I'd suggest that RAM isn't the likely cause.
  7. sandys
    sandys Well-Known Member
    26 Mar 2006
  8. Thewelder
    Thewelder Member
    27 Nov 2018
  9. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    If I've guessed the sticks correctly are they the hx432c16pb3k2...If they are is profile 1 for XMP setting the timings correctly (CL16-18-18) according to Kingstone's (PDF) documentation.
  10. Thewelder
    Thewelder Member
    27 Nov 2018
    Any ideas?
    Samsung evo 850 500 gig is new.
    Prime 95 runs no problem.
  11. adidan
    25 Mar 2009
    Have you investigated the game being the culprit or is it in several games?
  12. Thewelder
    Thewelder Member
    27 Nov 2018
    I will give u the part # later,I'm at work (on break)welding now :/ xmp gives 2 profile options ddr 3000,3300.timings sound correct for 1 of the 2.
  13. Thewelder
    Thewelder Member
    27 Nov 2018
    I recently upgraded my system to play only blk ops 4.I should install blk ops 1 and quake 3 and see,belive it or not guys still play them, very fast fun.
  14. TheMadDutchDude
    23 Aug 2013
    Even at auto, it’ll tell you what they’re at.
    They’re most likely waaaay too high, which is causing your instabilities.
  15. Thewelder
    Thewelder Member
    27 Nov 2018
    Hello
    What will tell me? (Games?)
    What's to hi?
    Ty.
  16. TheMadDutchDude
    23 Aug 2013
    In the BIOS, next to the 'auto' value, it should tell you.
    Failing that, download something like HWiNFO and get the readouts from there.
  17. Thewelder
    Thewelder Member
    27 Nov 2018
    Ahh OK gotcha I have hwinfo :)
  18. Thewelder
    Thewelder Member
    27 Nov 2018
    So to tight of timings your referring to as hi correct?......not loose?
  19. TheMadDutchDude
    23 Aug 2013
    No, I'm telling you that the voltages are most likely too high - nothing to do with the timings as of right now.
  20. Thewelder
    Thewelder Member
    27 Nov 2018
    Oic ok ....I worked til midnight last night and back in today at 8am..I will give u specs tonight afterwork.
    Ty
