Windows De-fragmenting your HDDs?
Discussion in 'Software' started by hirezo, 1 Dec 2010.
  1. Sexton
    Sexton Minimodder
    2 Jun 2010
    I have always used Auslogics Disk Defrag. Excellent piece of kit - run it on a monthly basis.
  2. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I use 0&0 defrag and have done for years.
  3. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Ooops. Why not?
  4. Deders
    Deders Modder
    14 Nov 2010
    Data can be accessed just as quickly from wherever it happens to be on an SSD, so defragmenting it is only going to shorten it's life with no speed benefit.
  5. Cleggmeister
    12 Oct 2009
    Thank you, good sir.
  6. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    Technically there is a (very negligible v. sequential as the file blocks are spread out) speed benefit, but SSD performance in random access is good enough to not notice it. Don't defrag.
  7. raxonb
    raxonb Minimodder
    5 May 2009
    I use Raxco PerfectDisk and my HDDs are in top notch condition. I was wondering though, that it is recommended not to defrag SSDs, but Raxco (and Diskeeper which is what my bro uses) both have options for specifically defragging SSDs. Has anyone tried this and found the SSD to perform better?
  8. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    +1 for MyDefrag with it being free and far more customisable than any other utility.
    Defragmentation utilities now rely on Window's defrag API so most only vary in providing a different display. So paying for a commercial program is almost pointless (SpeedDisk in Norton Utilities 2001 was an exception but had to be updated for every Service Pack).
  9. Dude111
    Dude111 An Awesome Dude
    7 Feb 2010
    In my opinion DEFRAGGING AND CLEANING THE REG is always a good thing :)
  10. j.col
    j.col Minimodder
    23 Dec 2010
    i use defraggler as well, pretty easy to use
  11. Deders
    Deders Modder
    14 Nov 2010
    Except when the reg cleaner cleans the wrong thing and your programs no longer work
  12. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i always advise my customers not to use registry cleaners, as they often remove things apparently not in use, then you wonder why some application isn't working.
    Teelzebub likes this.
  13. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
    I used to use Defraggler regularly, but being a frequent user of Ninite, I noticed another defragging program pop up in their list and decided to give it a go - Auslogics Disk Defrag.
    I might be imagining it, but I think it might be a tad quicker than Defraggler. Also, I was able to put a tickbox against all my hard drives and it defragged them in sequence and shut my PC down afterwards, I don't recall being able to do more than one with Defraggler :thumb:
  14. sk8roy
    sk8roy What's a Dremel?
    12 Sep 2009
    Same here best one Ive used. However the only drive that I ever defrag is my 'junk' drive that i use for downloads. Never find a need to defrag my main drive because I always do a fresh install of windows every 2-3 months.
  15. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Trying to backup a new Steam download without a defrag in between, killed my final XP installation, as it was too much new stuff on the hard drive at once - this is a 200Gig disc where I'd use it to save radio shows, so it was getting 1.2Gb per week - then 10-12Gigs of one game plus the backup, all at once, killed the install though the data's still there.
    So when I know there's going to be more than 10Gig installed at once, normally a game - I'll always defrag before trying to do anything else, whilst they're happy to give Auslogics for free, I'll stick with that one.
  16. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    OFF topic:
    Never had a problem with CCleaners reg cleaner (been using it for years), plus you can always wind back if you do get any problems.
    On topic:
    I have used defraggler and the windows one. I marginally prefer the former.
  17. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I don't think it makes much difference, I let windows do it once a week but my harddrives when checked never have any fragmentation.
    It's like when installing graphic card drivers...do this, do that, turn around 3 times while it's installing, hop on 1 leg with ur finger on your nose....:rolleyes:
    People just get peace of mind doing this stuff.
  18. Dude111
    7 Feb 2010
    Yes... Its always good to MANUALLY LOOK AT WHAT IT FINDS before just deleting it!
  19. Mizakoto
    Mizakoto Problematica
    3 Jan 2011
    yeh it's really easy, it's also quite helpful, i've noticed some changes in speed
  20. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    if on 7, the built in actually is good enough in my opinion, it does it automatically and you don't have to even think about it anymore. for older versions ie xp / 2003 i liked jk defrag, but i think its called something else now. its freeware and seemed to be really effective, and didn't take an age to get it done either.
