Dead Hard Drive?
Discussion in 'Tech Support' started by wilkyboy, 7 Apr 2006.
  1. wilkyboy
    wilkyboy What's a Dremel?
    20 Aug 2005
    Hey Guys, my brothers P3, Windows 2000 PC has recently gone down. The problem is, when i go to start the thing up, it loads up normally until it gets to the "loading windows" black and white loading bar, where it then stops on the second bar. So i took the Hard Drive out, slaved it into my PC and booted it, my boot up freezes after it checks my CD drives for bootable disks unless i remove it. Is it a dead hard drive? Any ideas? Thanks
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    Your best bet is to download and run the drive manufacturer's diagnostic software on the disk. It should be available freely on their website :)
  3. wilkyboy
    20 Aug 2005
    Do you need to be in Windows to run it though? If so, i can't even boot to Windows while its connected. :S
  4. hitman012
    6 May 2005
    Depends on the manufacturer. Seagate, Maxtor and Hitachi all offer bootables AFAIK, not sure on WD though.
  5. z4114
    z4114 FACE!
    25 Jun 2002
    WD also provides bootable versions of their diagnostic program. Either floppy or CD IIRC.
