Displays Dead pixel help?
Discussion in 'Tech Support' started by ersa, 5 Nov 2009.
  1. ersa
    ersa New Member
    21 Aug 2009
    hi
    i want to knew what make dead pixel come and i have 3 dead is the warranty cover it or it must be 5 dead pixels ????
    thanks
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    What display is it?
    Where did you buy it?
    When did you buy it?
  3. Xonar
    Xonar New Member
    2 Nov 2009
    Depends on the company, I know Dell have a no dead pixel gaurantee on their monitors. You can either try searching online for a peice of software that you can run and can sometimes jumpstart pixels back to life, or if you try giving the pixel itself a tap with your finger that can help fix them.
  4. ersa
    ersa New Member
    21 Aug 2009
    its samsung syncmaster 943nwx
    i try to put my finger but it didnt work
    and i bay it from 7 months i have 3 years warranty
    but i think it must be a 5 dead pixels to make warranty fix or change it
    but i want to knew what make dead pixel come
    thanks for all
