Cooling Dead Pump bleh
Discussion in 'Hardware' started by DarkLord7854, 22 Jan 2007.
  1. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Well, pump died on me in the middle of Bf2142 (great timing huh), temperatures rocketed to 120 degrees Celsius before the motherboard shut everything down, burned my hand when I tried getting a temperature read-out.
    So anyways, anyone got a suggestion for a pump? I believe I use half inch diameter tubing, it only cools the CPU so don't really a super powerful pump. I bought the Thermaltake BigWater SE kit (http://www.newegg.com/Product/Product.asp?Item=N82E16835106063)
    It actually works quite well for the P4, but since I had to cut-off the support struts I can't switch back to a conventional air cooled CPU, unless someone knows of a fan that has it's own support and doesn't require the stock motherboard plastic support thing.
    Help is greatly appreciated :)
  2. Krikkit
    21 Jan 2003
    Well this thread on XS has always been helpful to me. They have a great WC section. :D
  3. DarkLord7854
    22 Jun 2005
    :worried: :eeek: :blah:
    Can I just get a "Here get this, it will do just fine: <link>"
    :hehe:
    I'll have to read that thread tomorrow when I'm more awake, thanks for the link. :)
  4. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Although you could probably find it cheaper.
  5. DarkLord7854
    22 Jun 2005
    Wow, 90$.. that's 70% of the price I paid for the watercooling kit o_O
  6. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Yea I have found that, but the quality is so much better. I made the mistake of getting the Bigwater kit, quite frankly, air pwns it. I suggest this to be the starting point for upgrading your loop.
  7. DarkLord7854
    22 Jun 2005
    Thanks for the replies :)
    I was thinking of a DangerDen pump instead, since I'm very limited on money for now, but really need to get this loop back to operational status.
    Was also considering adding a waterchiller into it, not too sure how one works and stuff, but I've heard some people talk about them instead of using vapour cooling. Any thoughts?
