Scratch Build – In Progress Deamy Water [Desk Build]
Discussion in 'Project Logs' started by ronny78, 15 Aug 2015.
  1. ronny78
    ronny78 Active Member
    13 Aug 2015
    Hello everyone!
    My Name is Ronny.I would like to present you my Project.
    I wanted to see my Hardware and all components under a glass top.
    So i build a Showcase as a desk.I startet my Project in february and work every day and every Weekend.
    So slowly, it´s done.
    Hardware:
    Intel Core I7 3770K@ 4,6Ghz
    Asus Maximus V Formular
    32Gb G.Skill TridentX 2400Mhz
    Palit Geforce 970GTX Jetstream
    V1000 Power Supply
    water cooling:
    Laing DDC Plus
    EK X Top DDC Plexi
    EK-FC 970 GTX-Nickel
    EK Supreme LTX CPU-Kühler
    EK M5F Mainboard-Kühler
    1x Phobya G-Changer 480 V2
    1xAlphacool Monsta 480
    Phobya Balancer 1x250,3x450
    18x Monsoon Hardline red and black
    2x Monsoon Rotary 90°
    2x Monsoon Rotary 45°
    Monsoon Acrylicube UV-red
    6x Alphacool HF bulkhead black
    1x BitsPower drain cock Shiny Black
    My last Tower (CM Cosmos1000) but this time I 'm doing it right:
    Here the final pics and then the worklog.
    the complete worklog as a video
    Installing the Hardware as video
    A complete history exists in:
    PCGH-Forum
    and more different Worklogs :
    Hardwareluxx-Forum
    Hardwarereaktor-Forum
    we-mod-it-Forum
    (all in German)
    many thanks for Sponsoring to
    Stempel-Hauser GmbH
    [​IMG] for providing NB eLoop Series
    [​IMG] for providing V1000 Power Supply
  2. Cheapskate
    13 May 2007
    -Fixed
    Looks great.:D
  3. Icelander
    Icelander Member
    3 Mar 2015
    Can you get any longer reservoir. hehehehe..
    Looks good man
  4. arg-ist
    arg-ist Member
    21 Dec 2013
    It is very diffucult and dangerous , to criticize a nice worklog, but I would like to appeal to some things.
    Most of what I say are not problems of your case only. classic problem in these desk cases.
    You say: “I wanted to see my Hardware and all components under a glass top. “
    This is a PC case. main equipment in a PC case is MB. main thing that I want to see…
    But it is very diffucult to see MB in your desk. As if it especially hidden ..
    Of course we do not sit on the back side of the table
    Keyboard ,Mousepad and Mouse.., they should not be here.
    By doing this , you show yourself problems…
    If we get them to the right place…
    not much thing left…from the Show…
    if we can not do anything as design,
    We can use a smaller keyboard
    or we can use a mini keyboard on the glass desk.
    As Mouse we can use
    logitech Anywhere Mouse MX or Performance MX with darkfield technologie, to work on glass and
    we DONT NEED A MOUSEPAD on the glass.
    Friends which make a Desk case , must solve this problem .
  5. ronny78
    13 Aug 2015
    ohh yeahh, my Worklog is online , I received no notification.
    @Cheapscate
    Thanks , I did not manage to and can not see how you've done it now .
    @icelander
    Thanks
    @arg-ist
    you're right,I had unfortunately not much space to build it larger.
    The emphasis is not on "hardware" , but on "under glass".
    Finally, I look not always on the PC but on the Monitor
  6. ronny78
    13 Aug 2015
    all right, lets go
    my basic idea
    i buy Wood and take MDF
    i dowel and glue it, make the fan holes, installed the fan grills, a power supplie bracket and as you can see the Mainboard tray
    then i installed the aluminum angle
    and i painted it with spray can
    ready
    and i needed a cover for cable channel
    now i had to design the base frame
    i welded and painted it
    then i need the drive bracket, i take remains aluminum angle and acrylic glass
    the same for the HDD bracket with more style
    i have installed many LED´s
    READY
    i had black Radiators and paint them white
    later i got a alphacool Monsta
    well, i make all cable with paracord sleevs, was a good weekend
    the LED´s with sleevs
    a few ports for light and fan
    the buttons and switches
    a Weekend of work with tubing
    the insulation
    then i make a acrylic plate for the Mainboard for more clean optik
    i have covered them with foil. Aluminum black brushed
    on backside i used foam rubber for cable let through
    the same foil for all drives and hdds
    then i make a aperture for temperature display
    with reflectors and more White acylic for better light scattering
    i paint the Reservoir´s from nickel to black
    and make a Little cover for the Buttons-, Switches cable inside
    I am finished
    and the best for last,
    my desk won the second place on the DCMM (German Case Modding Championship)
    I hope you like it.
  7. Cheapskate
    13 May 2007
    Congratulations. Nice pic of you with Abbas-"I take all the trophies"-it.:lol:
  8. ronny78
    13 Aug 2015
    Thank you, he earned it.
    The man is unbeatable. :D
