Electronics Death Rays!
Discussion in 'Modding' started by Bogomip, 15 Dec 2002.
  1. rauter
    rauter What's a Dremel?
    15 Nov 2002
    I saw an article about a new technique to cut in all sorts of material. Believe it or not but they used water to cut through 1-2 feet of metal, like it was butter! :eeek:
    But of course the water was at high pressure.
    They even cut a camera in half with a very, very clean cut.
    The advantage with water then laser is that the water doesn't produce heat, which made the cut so clean with everything in the camera intact (except that they were in half ;) )
  2. Deymos
    Deymos What's a Dremel?
    23 Nov 2002
    They use water to cut marble, and planned to use it also in surgery...
  3. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    They usually add an abrasive.
    Again, easily available to those willing to shell out the high 5 figure sum to get one.
  4. Rod10k
    Rod10k What's a Dremel?
    2 Jun 2001
    They are developing a laser for mounting in the nose of the new JSF (joint strike fighter). AFAIK it is almost finished, they just need to finish the plane now!!!
    Power will not be a problem because of those big things called jet engines ;)
    Rod
  5. lcdman16
    lcdman16 What's a Dremel?
    19 Jul 2002
    "Ultrasonic Blaster
    Sonic Shockwaves Blow Holes In Metals!
    1/2 Quart Container
    40 KHZ 50 Watt Transducer
    High/Low Power Switch
    115 VAC Operation
    6"x 5"x1-1/2" Base
    Load Adjusting Circuitry
    Use to Clean PC Boards
    Jewelry, Coins, Small Parts
    Produce "Cold Steam", Atomize Liquids, Clean Objects!
    ULB1 - Plans......$10.00 ULB1K - Kit/Plans...............$99.95 "
    :eeek: :eeek: :jawdrop:
    oh man, i want one! blow holes in metal.... atomize water.... mmmm.... imagige the possibilities...
  6. Rod10k
    2 Jun 2001
    lol, probably more powerful than this one but you can buy the same at argos:
    Link
    Have seen and used them to clean pcb's and they are very good but they didnt come any where close to attomising water :) Sorry
    Rod
    edit: should have said that the pcb cleaners were much more powerful than that one from argos. The cost about £300 and you can get them from RS
  7. Loz
    Loz Blah Blah
    16 Apr 2002
    I don't think they've been successful in dissapating all the extra heat energy yet.
    With low efficiency theres a lot of it.
