A/V Decent closed back headphones £100-150
Discussion in 'Hardware' started by TrevDX, 25 Feb 2013.
  1. TrevDX
    TrevDX Ah Who Cares Anyway???
    9 Aug 2011
    I need to replace my in ear headphones with a decent set of closed back headphones these will mostly be used whilst travelling so must be closed back with minimal sound bleed and also rugged enough for everyday use.
    Anyone got any suggestions? I don't really know where to start with the exception of I'm never spending any more money on Beats after my last pair of in ear's sounded crap and lasted me less than 6 months.
    Thanks in advance.
  2. Tangster
    23 May 2009
    Beyerdynamic DT770
    TrevDX likes this.
  3. GeorgeStorm
    16 Dec 2008
    +1
    Mine are great, very little/no sound leakage, and they're rugged enough for travel I would have thought :)
    TrevDX likes this.
  4. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    TrevDX likes this.
  5. Tangster
    23 May 2009
    Richer Sounds sell them for £149.95 all the time. They never sealed quite right for me. I would advise a test fit before your buy.
  6. KidMod-Southpaw
    28 Sep 2010
    Beyers. You can't beat the DT770 for the money.
  7. TrevDX
    9 Aug 2011
    Thanks guys, I've got a few hifi shops around me so I'll try to find those and have a test run at least I now know the ones to look for.
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    See my sig! AKG 271 mkII
    can be found for just about £100 if you look around.
    A good friend has the original version for over 13 years now and still sounds great, detachable cable and new model comes with 2 1 straight and one coiled.
  9. docodine
    docodine killed a guy once
    10 Feb 2007
    dt770 is too bulky and don't fold
    they also kinda need an amp
    there are better options for portable use
    ...IEMs?
  10. ferret141
    ferret141 Minimodder
    18 Oct 2010
    +2
    I've been OK using my 80 Ohm pair on Pc, lappy and phone.
    There's a 32 Ohms version if you don't want to use an AMP
