Displays Decent Monitor £150 - £200
Discussion in 'Hardware' started by slim, 27 Dec 2011.
  1. slim
    slim New Member
    16 Oct 2011
    I'm after a decent quality Monitor for around the price as mentioned above mainly for pc gaming i've been looking at the LG IPS236V but i don't know if that the right one that's because there's some with a longer Model like
    LG IPS236V
    LG IPS236V-PN.AEU
    LG IPS226V-PN 22
    I have looked at some Samsung Screen as well mainly the SAMSUNG S23A350H i just want something with decent quality image and fast response time
    So if anyone could give me a list of screen and why it's good i'd be very grateful thanks :p
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
  3. Tangster
    23 May 2009
    For that pricerange I'd go for the U2312 Kernel pointed out, or the LG IPS231P-BN variant as it's now cheaper than the 236V and has a better stand.
    I own the 236V only because it was £135 when I bought mine(good £20 cheaper than any other IPS monitor).
  4. fdbh96
    fdbh96 New Member
    29 May 2011
  5. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    The LG 23'' is excellent, I'd definitely recommend it. I still can't believe how cheap it was.
  6. slim
    slim New Member
    16 Oct 2011
    LG IPS231P-BN seems a decent buy and the dell looks quite good and im sure has decent support behind it
    So either LG IPS231P-BN or the dell mentioned above seem to be a choice i wouldn't be disapointed with and i just have to be sure that i have the right model from seller some don't mention the BN part of the model and finding if there actually in stock
  7. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    The LGs are not being produced anymore (me thinks). I'd say go for the dell for an easy time.
  8. Cookie Monster
    Cookie Monster Well-Known Member
    27 Aug 2003
    I'll be watching this thread, I'm currently thinking about getting rid of my 2 x 22" Samsung Syncmaster 2232BW's, so far this is taking my fancy.
  9. SleepyMatt
    SleepyMatt New Member
    4 Sep 2011
    I have the Dell U2312 - absolutely love it! I haven't seen the LG to compare but have heard it is meant to be decent. To be honest usually these threads all say one or the other depending on your budget/preference!
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
  11. slim
    slim New Member
    16 Oct 2011
    Thing is the 8ms of the Dell U2312HM is alittle to big to be honest dunno if it would be to much of a risk to go for it
  12. slim
    slim New Member
    16 Oct 2011
    I decided to go for the LG IPS236V-PN is that good for gaming cos it's what i need it for
  13. Tangster
    23 May 2009
    Works fine for me.
  14. fdbh96
    fdbh96 New Member
    29 May 2011
    I have the older version and IMO I cant tell any dfference, but it does look amazing.
  15. azrael-
    azrael- I'm special...
    18 May 2008
    Quick recommendation from me: Dell U2412M, Dell U2312HM or ASUS PA238Q. The latter one apparently beats the Dell offerings if PRAD.de is to be believed (and that's usually the case :)). They also have reviews for the U2412M and the U2312HM.
  16. slim
    slim New Member
    16 Oct 2011
    I recent orderd the LG IPS236v-pn but a LG IPS235v-bn was deliverd. I looked at the lg page and spec for spec there the same but a bit of me thinks i should still send it back because it wasn't the one advertised
  17. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Ah ha! so these are what TG has been harping on about
  18. azrael-
    18 May 2008
    You mean the bit about going back to a single screen...? :p
  19. thetrashcanman
    18 Nov 2010
    Partially yes, I think he wants to go back to a single screen as he's being kicked out of the study and into the cupboard under the stairs (long the hiding place of the PC gamer) but I don't think these screen's will be out for a little while yet so I guess he's probably going to something like a Dell u3011, unless there's are out soon, but I might be wrong :)
  20. RichCreedy
    24 Apr 2009
    i believe they are out now, but expect to pay big bucks for them 5 figures i'm guessing
