PSU Decent PSU Recommendations?
Discussion in 'Hardware' started by guitarbloke, 2 Apr 2015.
  1. guitarbloke
    guitarbloke What's a Dremel?
    15 Feb 2015
    Not sure if I'm asking the impossible, but I'm after a reliable, quiet PSU - between 650-850w would be fine - but for around £80 or less.
    It'll need to fit into an NZXT H440 case. I'm not running SLI at the moment (maybe in future), but have a single GTX970 on the way. Other than that, 3 x HDDs (2 SSD and 1 mechanical) and an old i5 4570 (I think from memory).
    I was looking at the Corsair RM series (650w) but keep reading user reports about the cables being a bit naff. Anyone care to share an alternative opinion?
    Was also looking at the Superflower Leadex 750 which overclockers have for £84 this week, but some reviews report it as being noisy at full load and also quite a large PSU (so not sure whether it'll fit into the H440).
    Any other suggestions?
    Thanks guys! :D
  2. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    Check my sig for my recommendation
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    You really shouldn't look any further than the Superflower.
    I have the 650w version comfortably running an Intel 4690k, dual 970SLi, 3 HD's and 7 fans.
    The fan on the PSU itself is, to me, completely silent when it actually needs to come on which is very rarely, and i assume would occur even less on a 750w model.
    You won't have any problem fitting them in a 440 case BTW.
    EVGA PSU's which also have a very good reputation are manufactured by Superflower but without the white LED connectors and a longer 10yr warranty.
  4. dwnelson
    dwnelson What's a Dremel?
    19 Mar 2015
    All of these are OEM mfg by Seasonic and have good reviews.
    Corsair CMPSU-650TXV2 110
    Corsair TX650M 105
    Seasonic X-650 (SS-650KM3 Active PFC F3) 110
    XFX Pro Series Black XPS-650W-3XB (P1-650X-XXB9) 99
    Seasonic Platinum-660 (SS-660XP2 Active PFC F3) 140
    Cooler Master V RS-700-AFBA-G1 155
    Corsair CMPSU-750AX 160
    XFX Pro Series Black XPS-750W-3XB (P1-750X-XXB9) 120
    XFX Pro Series Black P1-750B-NLG9 120
    Corsair CMPSU-750TXV2 120
    Corsair TX750M 115
    Seasonic X-750 (SS-750KM3 Active PFC F3) 130
    Corsair AX760 160
  5. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    +1 on evga g2 psu, or pretty much anything from super flower
  6. guitarbloke
    15 Feb 2015
    Thanks for all the suggestions guys! :thumb:
    I'm going to go for the Superflower Leadex I think - the reviews seem great!
