Memory Decent RAM for MSI NF980-G65 AM3 motherboard.
Discussion in 'Hardware' started by dead beat, 23 Nov 2009.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    I've just bought this motherboard for my Phenom 2 955 BE. However I was hoping people could recommend me some RAM for this board.
    I'm looking for 4GB for now unless there are any good deals on 6GB. I'm after 1600mhz memory really, and have about 80-100 pounds to spend.
    Cheers
    Dead beat
  2. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
  3. dead beat
    15 Feb 2009
  4. barndoor101
    25 Oct 2009
    it shud be. DDR3 is DDR3 after all. but yeah, the crucial one looks a cracking deal. but be a bit wary because you might have trouble in the future finding a proper match if u ever want to max out to 8gb
  5. dead beat
    15 Feb 2009
    The only reason I asked is because in the description, it mentions that it's designed specifically for intel platforms.
    I take it that with the board I have, I will be requiring 240pin dual channel RAM?
  6. barndoor101
    25 Oct 2009
  7. dead beat
    15 Feb 2009
    Good find.......cheers for that.
    I have to say I'm still tempted by the Crucial package though.
  8. barndoor101
    25 Oct 2009
  9. dead beat
    15 Feb 2009
    Yeh I expect i'll probably do that.
    I've heard quite a few reports of people not being able to run their ram at 1600mhz on this board straight out of the box. It looks like it automatically sets the ram to 1333mhz, and you have to do some tweaking to get the speed up.
  10. Guest-16
    Guest-16 Guest
    That's the same with every motherboard.
    DDR3 will always always be set to 1333MHz by the motherboard BIOS as a failsafe (that's JEDEC specification), so you have to input the settings manually to run it at 1600MHz. AM3 CPUs have a 1:4 multiplier for running at 1600, so its not too much fuss.
  11. barndoor101
    25 Oct 2009
    plus the JEDEC spec calls for 1.5v - you usually have to set it to around 1.65v to get the RAM running at full speed.
