Build Advice Decent specs for around £400?
Discussion in 'Hardware' started by liamr1984, 22 Oct 2009.
  1. liamr1984
    liamr1984 What's a Dremel?
    22 Oct 2009
    alright then people i know theres loads of these threads about but i wanted some more personal advice am looking to spends around £400 the specs for the computer ive seen are :
    1, Intel E5300 2.6ghz processor
    2, abit IN9 SLI fatal1ty mobo
    3, gb ram
    4, 250GB maxtor hdd
    5, 512mb Nvidia Geforce 9800gt PCI-e
    if anyone can think of any alternatives or have any idea's of the best place to buy the components from i would much appreciate it,
  2. adam_bagpuss
    24 Apr 2009
    prices of parts or is this a pre-built ?
    how much RAM ? what speed ?
    maxtor HDD will be pants.
  3. liamr1984
    22 Oct 2009
    2gb corsair ram 667mhz ram what hdd would you suggest
    processor £44.00
    graphics card £65.25
    motherboard £50.00
    ram £40.00
    this price comes well under what im looking to spend but am leaving alot of room for changes and thats why im asking here
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    What are you aiming to do with this system?
  5. liamr1984
    22 Oct 2009
    erm play some games, web browsing, just general home computer stuff
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Can you please expand on some games? Crysis? Sims 2? Age of Empires 1? How intense
  7. liamr1984
    22 Oct 2009
    wanted, hitman, command and conquer, maybe colin mcrae dirt 2, similar types of games
  8. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  9. liamr1984
    22 Oct 2009
    thank you very much where were these prices from, i do not need a nase as i have a thermaltake soprano to mount it in, is there an intel processor and motherboard combo that would match with this configuration?
    thanx again
  10. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    That looks pretty good - but you REALLY NEED more than 2Gb of RAM these days.
    If you're tight on budget, use the stock cooler and use the extra money to get 4Gb of RAM. :)
  11. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    True, or just dig around for an extra £30 or so for the 4GB, if you had Windows 7 it probably isn't necessary though, the prices are from http://www.ebuyer.com ... Is there an Intel configuration to match this... probably, would I recommend it... no... am I AMD biased... just a little bit :p
    But the intel match for this would be LGA775 and not particularly futureproof with its DDR2 and end of life socket
  12. liamr1984
    22 Oct 2009
    tbh i wont be moving from xp for a while as i'm not sure some of the programs i am using will be compatible straight away, i thought the extra 2gb could be added at a later date as its just a case of building a more reliable machine than i have at present.
  13. liamr1984
    22 Oct 2009
    ha brilliant that is what i wanted to hear about the amd setup,
  14. liamr1984
    22 Oct 2009
  15. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  16. bagman
    bagman Minimodder
    18 Apr 2009
    a overclocked e5300 will be quite a bit faster than a phenom II 545
  17. liamr1984
    22 Oct 2009
    bagman could you give me a spec of a machine that uses the intel processors and mobo combination that would be suitable, i want something reliable and am not keen on overclockin straight away and dont mind spending a little extra on something more, and i have a case and 650watt power supply so the £400 is for components only,
  18. bagman
    bagman Minimodder
    18 Apr 2009
    mobo http://www.scan.co.uk/Products/Asus...x16)-DDR2-1200-1066-800-SATA-II-SATA-RAID-ATX
    cpu http://www.scan.co.uk/Products/Inte...300-45nm-Socket-775-2x26-GHz-2MB-Cache-Retail
    cooler http://www.scan.co.uk/Products/Arct...1156-S775-AM3-AM2plus-AM2-939-Up-to-130-Watts!
    ram http://www.novatech.co.uk/novatech/...PC2-6400/800MHz/Crucial/BL2KIT25664AL80A.html
    gpu http://www.scan.co.uk/Products/1GB-...750MHz-800Cores-2x-Dual-Link-DVI-I-HDCP-Ready
    hddhttp://www.scan.co.uk/Products/500G...HD502HJ-SATA-3Gb-s-7200rpm-16Mb-Cache-8ms-OEM
    optical drive http://www.scan.co.uk/Products/Sony-AD-5240S-0B-24x-DVDR-12xDVDDL-DVDRW-x8-RWx6-SATA-Black
    comes to a total of very close to £400
    the board i chose is one of the best 775 boards
    cpu because you can overclock it to 3.7ghz and as good as a amd 720 overclocked
    cooler the perfect cooler fo you
    ram from one of the best ram manufactures and has led's on them
    gpu pretty fast graphics card and it is the 1gb version
    hdd cheap but fast
    optical drive does everthing except blu-ray and hd discs
  19. adam_bagpuss
    24 Apr 2009
    personally if ya planning to overclock fairly high id opt for DDR1066
    any major brand will do just find cheapest.
    what PSU do you have ?
    if ya need to save a bit of money you could opt for the ASUS P5Q pro instead of deluxe it will overclock to the same since your using air cooling. that is if you dont need the extra deluxe features.
  20. liamr1984
    22 Oct 2009
    im not looking to overclock imediatly as i have no idea of how to i just want the machine up and running to a nice level, i have an EZCOOL 650W Active PFC PSU, im just looking at the intel configuration that has been suggested
