Scratch Build – In Progress Deep Fried Nuclear NUC :D
Discussion in 'Project Logs' started by Sean-Blake92, 17 Jan 2015.
  1. Sean-Blake92
    Sean-Blake92 What's a Dremel?
    30 Nov 2014
    Having no proper mods under my belt I have decided to start small with a scratch build NUC case :)
    as I work in recycling I'm constantly looking around skips, stills and containers, now and then the thought pops up Hmmm would I be able to fit a computer in that?, I recently had this thought while looking at some old 7 KG gas butane bottles, if I were to cut the mid section out of a 7kg butane bottle and replace it with acrylic that might make a nice mod, anyhow the practicalities of such a mod are bad at best, so I decided to shrink the whole thing down to the level of the NUC :) hopefully making a more practical mod,but once this is completed and I have more experience I'm planning on a full ATX gas bottle pc :), another thing that has interested me is subversive oil computers, its my belief they are just amazing, messy sure but amazing, so I have combined them both and come up with my maiden mod, Deep Fried Nuclear NUC :D, here are some very rough sketches of what I have in mind. and questions please ask away :). and i will keep this updated with pictures and progress etc :)
  2. Arboreal
    21 Jan 2011
    Looks intriguing, always good to see upcycling.
    Have you bee following Cheapskates's Iron Turnip? He's fitted an ITX rig into a small cylinder.
    http://forums.bit-tech.net/showthread.php?t=276991
    Only question I have is, ITX seems quite small for a 7Kg gas cylinder [I use the Calor ones regularly], you'd have plenty of room for something larger in there IMHO.
    Good luck with your build
  3. Cheapskate
    13 May 2007
    Someone call me?:worried:
    -I'm looking forward to seeing what scrap you come up with for this.:D
  4. Sean-Blake92
    30 Nov 2014
    I was aiming to make every mod I make with recycled stuff, i currently shift 4tonnes a day of electrical waste, but for this mod I'm just using off the shelf stuff (lazy i know) xD, I'm aiming for just three materials, MDF, Acrylic tubing, and vinyl wrap :), i have just had a look at your project log cheapskate, nice mod btw :)
  5. amagriva
    amagriva Minimodder
    13 Jun 2009
    Hi! Just a warning: Don't meddle with subversive oils. They're dangerous!. At least, if you want to adopt a "Hoffa style" solution, don't use transparent acrilic... :worried:
  6. Cheapskate
    13 May 2007
    ...Not sure if mocking typo.:D
