News Deepcool announces 'frameless' MF120 Wi-Fi fan set
Discussion in 'Article Discussion' started by bit-tech, 27 Feb 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. adidan
    25 Mar 2009
    Can someone explain why I would need wifi fans?
    MLyons likes this.
  3. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    what about intakes?
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Because it will probably be the latest way to control your RGB everything.
    I'd be more worried about the frameless aspect, fingers and cables normally come of worse when it comes to fast spinning blades, then there's how they get around the tendency for air to spill of the ends of blades, something a frame reduces and directs.
    adidan likes this.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    To change the led colour while on holiday on another continent to confuse the person you asked to feed your cat?
    That is about the only "real use" I could think of.
    What it is in my opinion is just another pointless thing "invented" in the pursuit of bloating feature lists to make them longer than those of the competition without examining the value of the new feature.
    adidan likes this.
  6. koaschten
    koaschten What's a Dremel?
    24 Mar 2011
    So how are you going to generate any amount of pressure when trying to either push air through the fins of a heatsink or radiator when the option is to just spill out sideways and do ... nothing?
  7. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Yeah but form > function is the best way to design stuff :rollingeyes:
  8. Xlog
    Xlog Minimodder
    16 Dec 2006
    If it, by any chance, follows any standard or has open API - so you can sync them with your room lighting. Also I heard home assistants are popular now, so you could (theoretically) control the fans by voice.
    Also it give one more vector for attackers to get into your network, why wouldn't you want it?
    adidan likes this.
  9. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    It's time for another Good Idea, Bad Idea!
    GOOD IDEA: Implementing a short-range wireless control protocol for fans/pumps/RGB/etc to reduce internal cabling clutter and allow for an arbitrary number of fans to be controlled from a single device
    BAD IDEA: Doing it with WiFi
    Impatience likes this.
  10. adidan
    25 Mar 2009
    I may just be being dumb and half awake but how would it help woth cabling clutter?
    My fans have one cable, for power. These fans still need power and I can control via software and/or just set up with the profile I want.
    Even in the days when I had a fan controller those cables were the smallest in the case and were quickly moved out of the way.
    Not sure how a wireless control would help anything.
  11. Impatience
    Impatience Minimodder
    6 Apr 2014
    I've got the Corsair RGB fans, and they use:
    - Power cable each
    - Lighting cable each
    - Box for said cable
    - Another cable to connect to another box
    - Usb cable for connecting last box
    - Power cable for each box.
    To me, having one wireless box and then power cables would save a LOT of hassle cable-tidying
    adidan likes this.
  12. adidan
    25 Mar 2009
    Now I see.
    Seems like a lot of cables and boxes for fans. :confused:
    Can see them being annoying. I'll stick with my single cablers ta. :)
Tags: Add Tags
