Graphics Default display changing! Ati X1900
Discussion in 'Hardware' started by veryevil, 18 Aug 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, Ive having problems with my X1900 Master card as it will not keep my default monitor! Im running two displays my primary on the dvi( with dvi-dsub conv) and the other on the crossfire cable (again with convertor)
    When the mobo boots the display is on the primary monitor (on the left) but when windows boots it switches the primary monitor to the second monitor so it identifies the monitor on the right (on the Xfire cable) as the primary display.
    How do i make sure it keeps my display settings?
    Cheers
  2. DougEdey
    5 Jul 2005
    What did you use to set the primary display originally?
    I would suggest you use CCC if you're using windows
  3. veryevil
    veryevil Minimodder
    14 Aug 2005
    I have tried both CCC and windows it actually identifies the second monitor as number 1 when clearly on boot its number 2?
    EDIT: Just had another go in CCC and so far it seems to be working. God knows what was wrong!
    Cheers
