Cases Define R5 USB Header Issues?
Discussion in 'Hardware' started by gtiboy, 2 Mar 2016.
  1. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    Does anyone who owns this case have problems with getting the USB header ports to work? When using Asus P8Z77 Motherboards?
    It seems the cable to plug into the motherboards fits slightly loose therefore not always creating a connection.
  2. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    I got my R5 at Christmas and built my system into it mid January (so only been using it for 1 1/2 months); I'm running a Asus P8Z77 also and I haven't noticed any issues with the USB ports on the front panel (touch wood), nor did I feel that the plug was lose in the motherboard when putting it together.
    Not sure what to suggest?
  3. Deders
    Deders Modder
    14 Nov 2010
    I had a similar problem with a USB3 add in card, same result in 2 different cases. Only one port would reliably work.
