Portable Deleting partitions on a small USB drive
Discussion in 'Tech Support' started by pre, 25 Jul 2015.
  1. pre
    pre Minimodder
    24 May 2004
    So I recently used the autoimage USB tool for memtest86 and the drive I used is now seen as a 48Mb partition. I've tried using Disk management in Win7 to try to format/delete partition but when I right click the remaining partitions created by tool I dont have option to shrink or delete Volumes.
    Any other tools I can use?
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    In windows you will need to use the cmd line to address this. Windows dosen't expect removable drive to have partitions for some reason, so any options to work with them are unavailable in the gui.
    Open elevated cmd line and type diskpart. Type list disk, to find out what the flash drive is assigned as. Type select disk (disk number), then type clean all which will reset the disk to raw and remove all partitions.
  3. pre
    pre Minimodder
    24 May 2004
    OK cheers will try that
  4. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    I have a few drives that have this problem. will have to dig them out and try that suggestion. thanks.
    Sent from Bittech Android app
  5. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    be very careful with diskpart
