Dell 2007FWP issue...
Discussion in 'Tech Support' started by Buzzons, 20 Nov 2007.
  1. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Was watching a fast moving dvd tonight and i noticed some "glitching" (maybe) where some of the image would move faster than another (hard to describe) but it basically looked like a few lines across the screen. (tis really hard to describe -- hopefully someone will know what I mean)
    any one know why this could happen?
  2. kenco_uk
    28 Nov 2003
    I *think* you mean tearing. It's when the screen can't keep up (sync) with the action onscreen. It's usually fixed in games using vsync - see if there's an option in your dvd playing software?
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  4. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    **double post **
  5. blu
    blu What's a Dremel?
    22 Oct 2007
    you could also try to change the refresh rate of your monitor
    (using xp) right click desktop, properties, settings tab, advanced button, monitor tab, and the drop down box allows you to change the refresh rate.
    (using vista) right click desktop, personalize, display settings, advanced settings button, monitor tab, and the drop down box allows you to change the refresh rate.
