Portable Dell Axim X5 - is it the battery?
Discussion in 'Hardware' started by xen0morph, 6 Apr 2009.
  1. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    I recently bought a Dell Axim X5 PDA from ebay. It arrived boxed up, and brand new, but has obviously been sitting in stock for a few years.
    Upon connecting it to the mains it seemed to be charging - showed a red light that after a few hours turned green - it switches on and works fine on the charger, but as soon as i disconnect it, it loses power completely. Doesn't even work for a few seconds.
    The "Power" applet in the control panel shows it to have a 100% charge.
    Does this sound like the battery, or a hardware problem with the PDA? As it has been sat for a few years I think the battery may just be f****d, is this likely?
    I have tried charging it overnight and it made no difference. Also tried soft and hard resets.
    Also, can anyone recommend a good wireless card that will work with this PDA (Pocket PC 2002)?
    Cheers
    Rowan
