Notebooks Dell inspiron mini 10, BSOD
Discussion in 'Tech Support' started by guysy1110, 20 Feb 2011.
  1. guysy1110
    guysy1110 What's a Dremel?
    15 Feb 2007
    Im trying to repair a inspiron mini 10, Yeah i know... Dell... Hell?
    Its got the BSOD and i cant get into safe mode... im slightly out of touch with software repair so i could really do with some help, my local forums with the base of cars are usually ok but not helpful at this time...
    The laptop apparently was running fine, something was downloaded and then the BSOD, so i updated my virus protection on my test computer, pulled the hard drive and ran it on my test machine, ran a scan and found 10 Trojans ! those where removed...
    Now... how to do get the laptop running again? i would preferably like to run a program on my test machine to the hard drive as a slave to get it working..
    What program should i use... or i suppose it might be hardware, but the story im told im thinking virus editing the registry?
    Codes: 0x0000007e
    0xc0000005
    0x8656b562
    0xf7a207ec
    0xf7a204e8
    Many thanks!
  2. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
    Windows XP?
    Can you copy any important data from the HDD to your test machine?
    Did you receive a repair disk with the laptop?
    Can you enter the F8 menu on Windows boot and restore a previous System Restore?
    Cheers,
    SouperAndy :worried:
  3. guysy1110
    15 Feb 2007
    Im pretty sure its running xp yeah,
    There isnt any important data on the hard drive,
    its not mine so im not sure, but it doesnt have a cd drive, im waiting to see if i can borrow a cd drive from a friend later... a usb one, the only disk i have is a regular xp install disk... if i run this there should be a repair option right? and it could possibly work?
    Failing that ill ask the owner if they had a disk... the only thing slowing me down is no external cd driver atm...
    I haven't been able to get into F8... maybe once :S i cant remember how i did but i got into advanced boot and there was still no cmd line and i dont think a restore option...
    Thanks.
  4. Boldar
    Boldar Minimodder
    24 Feb 2003
