Displays Dell U2311H vs Dell U2312H vs IPS231P-BN vs Eizo FS 2331
Discussion in 'Hardware' started by Captain Awesome, 5 Nov 2011.
  1. Captain Awesome
    Captain Awesome What's a Dremel?
    19 Nov 2010
    Okay. Long title but it says all. I need a new IPS panel, and I'm getting one of those. In my country they are all roughly the smare price, even the new u2312hm.
    As the u2312hm is new i would seem like the best of them but with the reviews that do exist of the U2312hm says it has worse blacks then the 2311H.
    And the Eizo FS 2331 kindoff gives me a feeling it will provide, as it is an Eizo.
    At last the IPS231P-BN is allways a good IPS panel with lots of reviews out there who says it's great.
    Which is best, and why?
    Thanks in advance :p
    -CA
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  3. LennyRhys
    LennyRhys Oink!
    16 May 2011
    The Eizo 2331 is VA, not IPS.
    Between the others, the simple answer would be the U2311H - whilst it doesn't have a better panel, it has the best backlight (CCFL vs LED).
    But if it's for gaming, then really the entire comparison is straining at gnats tbh - they are all nice monitors.
  4. Elton
    23 Jan 2009
    The Eizo will have the best color reproduction hands down.
    Although it will cost about as much as your hand.
  5. 3lusive
    3lusive Minimodder
    5 Feb 2011
    If budget isnt an issue then my advice would be the Eizo because of its betters inputs (2x HDMI), colour reproduction (contrast and black depth are better than the other screens there), and cleaner looking AG coating compared with the aggressive ones on the Dells. Its a VA display so viewing angles wont be as good as the IPS ones, but how much you notice this is another matter altogether. Good review here where they actually compare it to the U2311 http://www.flatpanelshd.com/review.php?subaction=showfull&id=1288694516
    If we're talking value for money then its the LG hands down, though.
  6. Tangster
    23 May 2009
    If they all cost the same, get the Ezio.
  7. Pookeyhead
    30 Jan 2004
    Please do not assume VA is inferior to IPS. I had a IPS 30" screen and replaced it with a S-PVA Eizo 30" because the black level, dark tones viewing angle, and colour accuracy were FAR superior.
    Personally, my choice would be the Eizo.
    I'm not sure from memory, but I don't think the Eizo is LED backlighting, and I'm pretty sure it's CCFL.
    It is not very aggressively overdriven, which means low lag for gaming, but there will be some very slight trailing on fast movement.
    Black levels, colour accuracy and richness, and excellent contrast would still make the Eizo my first choice.
  8. GoodBytes
    20 Jan 2007
    If they are all the same price... heck get the EIZO.
    5 year warranty too.
    The only downside, is that the stand is not adjustable, and possibly slower than IPS due to the panel (depending on the performance of the overdrive circuit, and how fast the panel is).
    After weighting the up and down sides... the EIZO is clear winner.
    Better visuals, better screen (true 8-bit panel, from the looks of it), cool features, 5 year warranty and from a known and trusted name. At the loss of an adjustable stand (not that it can't be fixed with a monitor arm), and possible performance issue, if you play a lot of fast past games, but if you look at IPS panel already, I highly doubt it will be issue for you.
    I am really interested to know how it is, if you go this path, PLEASE PLEASE PLEASE give me lots of feedback, and pictures please :D
  9. Captain Awesome
    19 Nov 2010
    I can get the Eizo for less then the LG. Will the Eizo do for League of Legends in terms of ghosting/input lag?
  10. LennyRhys
    LennyRhys Oink!
    16 May 2011
    You're misreading what I wrote - I would say in a heartbeat that the Eizo is superior; the only reason I separated it from the rest was purely because OP said he wanted IPS - that's why I gave a recommendation choosing "between the others." Identifying it as VA was more of a correction than anything else. ;)
    BTW I had a look at the Eizo spec and the 360 picture very much makes it look like CCFL.
    @ OP yes get the Eizo... forget about ghosting and input lag, because it's not as big a deal as it's made out to be.
  11. Pookeyhead
    30 Jan 2004
    10-4
    The Eizo will have low input lag, but at the expense of pixel response speed, so some light ghosting. I'd say it's an acceptable pay off for s screen that is superior in every other way. I'm in the same situation with my Eizo. On fast pans from side to side in FPS games, it looks slightly soft. Am I bothered?
    LOL
    No.
