Displays Dell U2711 or triple LG IPS231P cheesecake?
Discussion in 'Hardware' started by Blogins, 18 Jul 2011.
  1. wyx087
    15 Aug 2007
    follow these steps:
    http://forums.whirlpool.net.au/archive/1511987
    otherwise your colour would be wrong.
  2. LennyRhys
    LennyRhys Oink!
    16 May 2011
    This is what I do for wallpapers:
    Type "jpg" into goole and do an image search, and specify the size (in your case 3840x1080).
    You should find a few :D
    You can experiment with different searches, eg a game, a movie, the name of a person, a design etc.
  3. longweight
    7 May 2011
    I have been doing that for a while and found a couple of gems, not much dual wallpaper around! :(
  4. Nikols
    Nikols What's a Dremel?
    13 Oct 2009
    I read all of this link eventually and ir looks like
    Standard mode - this will allow the widest colour gammet, so more colours but not calibrated
    Game mode - switches off aspects of the monitor to increase response time but unlike it's 24" brother does fook all really as response times don't really improve
    sRGB and RGB - (make sure a dell or adobe icc is set up) both are calibrated but RGB mode offers the wider colour gammet as long as what ur viewing is compatable ie able to be viewed in RGB. If it's not then it'll default to sRGB.
  5. GoodBytes
    20 Jan 2007
    Don't you mean 3840x1200. You got the 2x U2410, Right?
  6. longweight
    7 May 2011
    No sadly I have my work monitor (cheap samsung 1920 x 1080 TN) and then my own 24" slightly better samsung 1920 x 1080 TN for dual screen at work.....
  7. GoodBytes
    20 Jan 2007
    Ah ok, makes sense.
    So at home you have the U2711
  8. longweight
    7 May 2011
    Exactly, I think for work I will replace my dual set up with one 30" 2560 x 1660 IPS monitor. Doesn't need lots of features just screen space! Maybe a cheap Hazro?
  9. Guest-23315
    Guest-23315 Guest
    I disagree! I'd much rather have my 24" and 19" second screen than a single 27"
    Its now second nature for me to have my main task on the 24" and then email/itunes etc on the second.
  10. wyx087
    15 Aug 2007
    omg, ginger gunsmith? :lol:
    it's also now second nature for me to have my main tasks on the right of screen, then itunes/iplayer/VLC on the left. 2560 width :p
  11. Guest-23315
    Guest-23315 Guest
    3200 ;)
  12. wyx087
    15 Aug 2007
    but can you game on all of your 3200 width? how about play a video at 3200 width? :p
    love what you've done with your hair :)
  13. Guest-44432
    Guest-44432 Guest
    6030 width, and yes I do game on all my width, single monitor gaming sucks now. Triple monitor gaming is the future, and allot of games run flawlessly on it. When on desktop it is nice to have 1 monitor for web browsing, another for emails, and the other for running apps etc. I prefer the space of 3 monitors over my 3008wfp I use to have.
  14. longweight
    7 May 2011
    I plan to stick 2 monitors either side of my U2711 but I need to save up for a second 570 and 2 additional monitors!
  15. DIZZY DAZZLER 2010
    DIZZY DAZZLER 2010 Tech nut!
    23 Feb 2010
    I got lost reading the link! Can anyone simplify the instructions to get the best out of the U2711. As mentioned I am in GAME mode at the mo and the colours are ace!
  16. wyx087
    15 Aug 2007
    do this:
    1. Set your U2711 to adobe RGB mode. make sure all other settings are default.
    2. click start in windows, search "color management"
    3. select the U2711 display
    4. click use my settings
    5. click add, then find adobe RGB. if there is no adobe RGB, you'll need to download the icc and install it before proceeding
    6. select the added adobe RGB, and set as default.
    7. you need to repeat this with your other u2711 monitors separately.
    8. go to advanced, and make sure windows color system defaults to sRGB (not adobe RGB)
    9. do not click calibrate display! dell's factory calibration for adobeRGB is more accurate than your eyes.
    10. restart computer
    game mode is useless and doesn't let you get most out of the monitor. plus the dynamic contrast is really annoying.
  17. DIZZY DAZZLER 2010
    23 Feb 2010
    I have now done this and my monitor is set to use adobeRGB1998.icc as default, is this correct as the colours seem a little washed out compared to game mode. Is it a case that game mode is too harsh and I have grown used to it?
  18. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Less pretty colours in game mode, now you're seeing everything in Adobe RGB mode!
  19. DIZZY DAZZLER 2010
    23 Feb 2010
    So am I set up right now then as just played bad company 2 and it does look fantastic compared to my old TN panel! I assume I am now seeing the colours that the game should be displayed in.
  20. GoodBytes
    20 Jan 2007
    Assuming they didn't use TN panels to draw :p, then yes you are seeing the right colors... well just so that I am not going to be bashed by professionals around here: very close to it.
    To really get the exact reproduction, you need to buy a color calibrator to generate a proper ICC profile matching your monitor (and not someone else, as this is what you are doing).
    I am going to give this a try, and tell you if it's washed out or not on my side, or if it's the correct colors. Well "correct"... assume very close to them.
