Displays Dell Ultrasharp 2209WA 22" worth a purchase?
Discussion in 'Hardware' started by Whitlog, 4 Apr 2010.
  1. Whitlog
    Whitlog What's a Dremel?
    26 Jul 2004
    Hey
    After having my LG Flatron L1710B for many years I feel its time to upgrade.
    So as the title states I am thinking at buying the Dell Ultrasharp 2209WA 22", it hits my max price range and I have read good things about it.
    anyone got one and how you finding it? or is there others for the same price or less that I should also consider.
    Thanks for your input :thumb:
  2. azrael-
    azrael- I'm special...
    18 May 2008
    Only buy it if you want a truly brilliant monitor. :)
    While I do not have one myself, I was instrumental in getting 4 of them for testing at the company I work for. Didn't take long and we ordered another 30.
    Colours and viewing angles are truly superb as befitting a monitor which uses an IPS panel. Ergonomically it's also great with a rotating height-adjustable stand and pivot mode.
    Off the top of my head there are two other monitors you might want to look at. There's the LG W2220P, which (to my knowledge) uses the same 1680x1050 16:10 panel as the 2209WA and which might be a bit cheaper), and there's the NEC EA231WMi using a 1920x1080 16:9 IPS panel (and is somewhat more expensive).
    If you're into true hardcore gaming, however, you may want to pass on monitors with IPS (or xVA) panels, since they have somewhat slower response times than cheaper TN panels, which in turn pretty much suck when it comes to image quality.
    Whitlog likes this.
  3. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I've got one and I can confirm it is a great monitor and well worth purchasing. I game a lot and there is no issue with ghosting, colour depth is fantastic and no banding. Games look fantastic with this monitor which was my main reason for purchase.
    Whitlog likes this.
  4. haddow64
    haddow64 What's a Dremel?
    24 May 2009
    I got a pair and they are fantastic, no problems at all with them. I am currently saving for a second 275 and 3rd one of these monitors.
    Whitlog likes this.
  5. Whitlog
    26 Jul 2004
    Hey
    Thanks all for the feedback, like I said I have read good things about it but I always prefer to hear peoples view who own the hardware, always feel you get a better picture
    thanks again for the advice, I know what a chunk of my next pay check is going on :)
  6. eek
    eek CAMRA ***.
    23 Jan 2002
    I agree, they are great monitors! I have 3 of them sitting on my desk at work and can't fault them. Not gamed on them (obviously) but I can't see why they wouldn't be more than adequate.
    Whitlog likes this.
  7. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    Whitlog likes this.
  8. Whitlog
    26 Jul 2004
    thanks eek
    and cheers jbloggs for the great review
  9. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    dell 2209wa Cheesecake !
  10. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Make sure you want 22 and not 24", the screen is the best 22" there is, rich colours.
    nice avatar above!
    Whitlog likes this.
  11. GravitySmacked
    2 Mar 2009
    Aye it was an iconic film (for me anyway).
  12. kovacs
    kovacs What's a Dremel?
    17 Mar 2010
    Why obviously, i have cod 2,3 and 4 on my work pc.The I.T guys at work even let me run my old 4850 on it.They even set my internet connection to bypass the web content filter:rock:
  13. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    what film are you thinking of ?
    its picture of my desk lamp
  14. Elton
    23 Jan 2009
    The 2209WA is definitively worth the purchase.
    Even if the quoted response time isn't that brilliant, it's more than enough unless you have some crazy eyes.
    I use a 20ms S-IPS monitor and I don't really notice it too much, if at all, that 2209WA should definitively be better.
  15. GravitySmacked
    2 Mar 2009
    I believe he was talking about The Black Hole.
  16. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    I have the Dell 2408WFP and that screen is great, but after purchasing the 2209 I think its actually less vibrant while being far more expensive so i strongly recommend the 22".
  17. Ergath
    Ergath Giant Zombie Pigeon Photographer
    6 May 2009
    I've had a 2209WA for a year or so, bought on advice from this forum and many other similar places on the interwebs. It looks OK, till you turn it on... and then it looks fantastic. Apart from anything else it's nice being able to show somebody something on the screen and know that it looks very nearly the same from their angle as it does from yours.
    In conclusion:
    :thumb:
  18. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    I've already posted in a topic like so before so I'll just quote myself:
    Only thing I'd add to that is that I see an ever so slight pink tint on whites which naked to most peoples eye's gets right on my nerves to the point I'll most likely be buying a calibrator soon. Other than that it's great.
  19. Elton
    23 Jan 2009
    Lower your red color on the RGB values, or...increase green + Blue.
    I still do calibrations by eye, if only because I've had a VERY well calibrated CRT for years.
  20. thefriscokid
    thefriscokid why s**t so crazy?
    30 Aug 2005
