Hello all I recently acquired an old Dell XPS 400 Socket 775 Pentium D 820 at 2.8 Ghz 1 Gig of DDR2 (2x 512 sticks, 4 slot total, awful decision Dell ) Nvidia 7300 LE 400 Watt PSU 1 160 gig sata drive I have started been playing League of Legends with this setup. At 1920x1080 I have been getting 25-18 or sometimes as low as 10 FPS with all graphic options turned to Very Low. My question to you, oh faithful bit-tech readers is should I bother upgrading this PC? I figure I could have a decent PC for 100 to 150 bucks if I shop around, or I could just sell it down the road for a little extra cash, as the tower didn't cost me anything. So should I get a Radeon HD 5670 and 2 gigs of RAM for 100, a GTS 450 and 2 gigs for 120, or a 460 and 2 gigs for around 150-160 after MIRs? My wallet is in your hands gentleman. Thank you in advance
Back in the days, 1GB of RAM was a lot for many if you picked XP OS. You won't go far with a Geforce 7300 especially not the Lite Edition. The bad decision from the person who bought this, was the Pentium D. Upgrading the GPU will help, but the Pentium D will limit you big time, in my opinion. I don't know why you bought this system. If it was a Core 2 Duo, that would be a different story, as it's significantly faster CPU, and a descent med range GPU will provide a lot of performance. But I won't go anything about a Geforce 450 or even a Geforce 280, with 3 or 4 GB of RAM total.
If you did get a 460 or 560, you would see a significant improvement once you decide to upgrade to a faster CPU, a 450 although good for 1680x1050 with no AA, wouldn't be worth it for 1920x1080.
Didn't pay a dime for it, so at least i have that going for me. I figured this might be a bust, but I was hoping for the best . Hey, at least I have another PC to mess with. Thanks Deders and GoodBytes for the advice though.
If you put in a low end card it would be cpu bottlenecked but LOL would run fine at lower setting. Any more modern games though...
These days it's better to have an overpowered GPU with a underpowered CPU than the other way round, if they are the only choices you have.
Try and get some more ram if you decide on another graphics card.Otherwise start from scratch. Also the 400w PSU is probably a dog.
