Delta fan at 5 volts, quiet?
Discussion in 'Hardware' started by seb835, 1 May 2002.
  1. seb835
    seb835 What's a Dremel?
    31 Jan 2002
    Thinking about sticking a delta 80mm fan on my alpha pal 8045 instead of using the vrappy Evercool low noise fan..
    but is the delta almost silent at 5 volts setting? or does it still scream like a biatch?
    thanks
  2. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    A delta at 5v would probably spin so slow it would be easier to just get a Mechatronics 53cfm or a different fan that is quiet and has good airflow.
  3. cderalow
    cderalow bondage master!
    23 Jan 2002
    delta @5V wouldn't spin.... i think the startup is 5.5 or 6V, but I forget... Delta@7V is fairly quiet... about the same as a VGA cooler
