Cooling Delta Temperatures
Discussion in 'Hardware' started by GrandeP, 6 Aug 2012.
  1. GrandeP
    GrandeP What's a Dremel?
    13 Sep 2011
    Call me a noob but what exactly is the purpose of delta temperatures? I know that you take the ambient temperature away from various cores/graphics cards.
    It is something I have never understood. :duh:
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    the delta temperature is the temperature difference between how hot something is and the ambient temperature.
    Like, my room ambient temperature is 20 degrees, my cpu is idling at 28 degrees, which is 8 degrees delta. Its a useful way of quantising cooling performance.
  3. theshadow2001
    3 May 2012
    By stating the delta temperature, you ignore the effect that the ambient temperature has on the cooling and so removing that variable from the benchmark. If you just stated temperatures as they are read from the system the results of a test would vary wildly depending on whether the room was hot or cold, done in summer or winter or even the time of day.
  4. doyll
    doyll Minimodder
    1 Jul 2011
    I think of it as the opposite.
    Ignoring the ambient temp gives your temps that mean nothing where as subtracting ambient temp gives you the actual rise in temp.
  5. asura
    asura jack of all trades
    22 Apr 2009
    Ignoring wasn't best choice of words; you're both saying the same thing, remove the ambient temperature from the CPU load temperature to produce a figure which is easier to use in comparisons, imagine the graph with the ambient and load figures instead of just the delta T figures, they become harder to read.
    Some people go the extra mile and produce C/W figures, these are even easier to read and use from chip to chip.
  6. Shirty
    18 Apr 1982
    Exactly, comparing absolute temperatures is arbitrary considering that one test could be performed in a room at 18°C and the same test in another room at 28°C. Clearly the absolute temperatures recorded in the second room will be 10°C hotter.
    We normalise this by removing the ambient temperature from the equation. Doing so will allow you to calculate the absolute temperature you would achieve using the same hardware in the room of your choice, simply by adding your room temperature on to the delta temps.
  7. doyll
    doyll Minimodder
    1 Jul 2011
    CPU temp - ambient / watts disipated (how much ur cpu outputs) = C/W. So have to use some software to determine CPU wattage? No thanks.
    I'll stick to using CPU temp - ambient = delta. I don't know of anyone who can tell me how many watts my CPU is using ;)
    Something I never see is what the humidity is during testing. Moist air cools better than dry air because the moisture absorbs heat. ;)
  8. Shirty
    18 Apr 1982
    Of course, no two chips are exactly the same, so it's always worth bearing in mind YMMV and taking the published figures as a guideline rather than gospel ;)
  9. asura
    22 Apr 2009
    Not difficult to get C/W at all! Simply build a small reservoir around your exposed chip add 1g of water, measure the time (t) it takes to raise the temperature of the water by 1C, divide 4.186 by t and you have your answer! :lol:
