LOL Demotivational Posters (NSFW)
Discussion in 'General' started by boiled_elephant, 7 Dec 2008.
Thread Status:
Not open for further replies.
  1. logan677
    logan677 WTF is Starcraft 2?
    25 Jul 2009
    i loled good show have some rep:rock:
  2. Guest-23315
    Guest-23315 Guest
    Umm I call fake.. Take a look at the bus in the foreground and its wheel poitioning.. it looks like its power sliding..
  3. roblikesbeer
    roblikesbeer Bindi's sex slave.
    23 Apr 2009
    I find rap music so demotivating...
  4. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    It's making a turn lol.
  5. Stewb
    Stewb What's a Dremel?
    16 Dec 2009
    It is a fake, look underenath the car as it starts to flip, a "launch arm" for lack of a better word can be seen.
    EDIT: Attached to the right, rear wheel
  6. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Wrecking balls not allowed in NYC, a hydraulic flipping arm under the rear. Fake / Movie set for sure
  7. tyrandan
    tyrandan Pink Lemonade.
    2 Mar 2009
    Yes, the bus is turning. Another: If a car gets hit by a wrecking ball, why would it need a "launch arm" to roll?? that would be over-kill. I think it's actually a piece of the bumper or perhaps the axle. Because the "launch arm" looks too weak to carry the whole vehicle's weight, even for a split second, and it has no triangular support. It would probably bend before rolling anything. Definitely bumper or something. maybe one of those underside support beams.
  8. Aaeen
    Aaeen Yep...that's me
    10 Feb 2010
    The new movie "The Other Guys" starring Marky Mark and Will Ferrell...
    Source
  9. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    lolololololololol
    I'm pretty sure you can hear the air shoot out when the lever flips out.
  10. tyrandan
    2 Mar 2009
    The pikachu pic made me cry a little. Rofl.
  11. aradreth
    aradreth What's a Dremel?
    20 Aug 2009
    Yes because it isn't a really wrecking ball or else you'd see a lot more damage to the side of the mini van.
    If that isn't enough you can tell it isn't a real wrecking ball as it looks to be about 1m in diameter which means a volume of ~4.2m^3 and steel (what they tend to be made of) has a minimum density of around 7100kg/m^3 meaning it has a weight of close to 30 tons and is stopped by something weighting 2tons or less.
    Edit: just though 30tons for a wrecking ball? Seems a bit high I think I might have done something silly. Max weight for a wrecking ball is probably closer to 7-10tons so the point still stands...
    Edit2: How the hell did I get 4.2m^3? Should be 0.5m^3 (3.55ton wrecking ball). Ah bollocks I need to sleep.
    Edit3: I used 1 meter as a radius instead of a diameter when working out the volume :duh: last edit I promise...
  12. tyrandan
    2 Mar 2009
    Touche my friend. Touche.
  13. Stickeh
    20 Jul 2003
    I was about to say, the easiest notion of it being fake, the ball wouldn't stop hitting a minivan, woulda threw it across the road !
  14. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    I'm glad to see my link caused such a reaction, but fake or not it would still ruin my day if it happened.
  15. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
    If it happened, it would ruin your life. It would most likely end it however.
  16. Aaeen
    10 Feb 2010
    Dump #2:
    Ah...now I get it
    Keep it under 88
    Just missing the hobbits
    That one techno song
    Oh shiiiii
    Wish this worked
    What's worse?
    o_O
    WHAT?! YEAH!!!
    Lost...control?
    True
    Explains that
    Girl power?
    Progression
    New Game: Final Fantasy X-3: Letting Go
    Might want to tidy up before posting on Ebay
    Remind me to never go to Australia
    Pretty close don't cha think?
    eye test
    Don't want to even if I could afford
    BLAST OFF!
    Miley...oh Miley
    r4st4m4n likes this.
  17. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Anybody else get the urge to scream "BOOMER!!!"??
    Moriquendi
  18. Aaeen
    10 Feb 2010
    BOOOOOOOOOOOMMMMMMMEEEERRRRRRRRR!!!!
    o_O
  19. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    There are times I wish I could repeatedly kick you about the face and neck :grr:
  20. Aaeen
    10 Feb 2010
    What I read
    What was actually thought
    Damn...he beat me. Must target rage!
    I ♥ you Gunsmith.
Thread Status:
