Modding Design help/ideas
Discussion in 'Modding' started by <A88>, 31 Mar 2004.
  1. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Would a 600mm square cube made out of 3mm clear perspex be strong enough to house a computer set up normally (mobo on right hand panel etc)? Also, any design ideas for this project?
  2. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    To put it bluntly........no. You would need at least 5mm and i dont think that would be thick enough. About 8mm ish would be about right i think.
  3. <A88>
    10 Jan 2004
    Thinking of putting 10mm pillars scattered around case to suppurt it?
  4. kill_me_quick
    7 Jan 2004
    I still dont think it would be strong enough, if you pick up a sheet of acrylic it bends like hell.
    You could give it a go, but i wouldnt think it will work and unless you can get it for free. It will cost a bit too.
