Networks Designing a home / small business network
Discussion in 'Hardware' started by rooroo, 1 Sep 2012.
  1. rooroo
    rooroo Minimodder
    15 Jun 2003
    Hello
    Im planning a home / small business network.
    Currently we have rural 2mbps broadband and 54g wifi but soon we are getting bt infinity, not only that... My mrs runs her business from an outbuilding at the end of our garden.
    I'm planning on running 2 cat6 cables from the house into the outbuilding,
    They will connect to a gigabit switch in our utility room .. That will connect to the infinity router.
    Also I'm planning on running 4 cables into the living room to a faceplate, two Into my stepsons bedroom to a face plate and two into the other bedroom
    Basically
    Router---switch---spur off into rooms
    Is cat 6 cable the right stuff to use for gigabit?
    I have purchased a netgear gs116 to get started
    Any advice
  2. steel_viking
    steel_viking What's a Dremel?
    6 Jun 2010
    I have a similar setup in one building. Cat 5e cable would be fine.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Cat5 inside the house will be fine for many many years to come, I'd go Cat6 for the outside link just because it has better shielding.
    I assume you'll be running the outside links in some kind of conduit? Plastic pipe is always a good choice as it's cheap and the plastic compression fitting are easy to use too.
    Any reason you are running two links to the bedrooms? I'd just run one and then put a switch at the end of the link if you need more connections, you're not going to get close to swamping a GbE link with most consumer devices. Maybe two for the front room, but again four seems overkill?
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Running multiples to a room seems like a great idea to me if you are putting them on each wall or something like that. Keeps more freedom to arrange things.
  5. rooroo
    rooroo Minimodder
    15 Jun 2003
    There is already a trench in the garden, I thought, stick the cat6 into the garden as it will be buried, it will be easier in the long run to future proof I might just do 2 to each room.. In the future all TVs will have ip features so seemed to make sense to have 1 port ready and another for a computer, I'm glad cat 5e is good for gigabit... So much cheaper :)
  6. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    I'd also replace the BT Infinity router with something like a routerboard - more stable, handles the data rates better etc. Only £50 from linitx too :D
  7. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    Am using that switch to connect all the rooms in my parents house, and it does a very fine job. Good buy!
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    I'd defiantly put it inside some kind of conduit, I doubt that the outer plastic of the cable itself is rated to be waterproof and likely won't survive any organic matter ingress (roots or otherwise).
  9. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    remember you will need to put the cable through a PVC tube to protect it and make sure to make detailed plans in case you ever sell the house. position depth ect. You will want horizantal reinforced CAT6e cables
