Open Source designing something in 3d
Discussion in 'Software' started by chrisb2e9, 1 Sep 2012.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Hi,
    I have decided that because I suck at flying RC helicopters. And my rc boat build is on hold until I regain interest. I want to make a RC truck.
    But I want to make it in 3D first on the computer.
    Does anyone know of any good free programs that are easy to use for new people?
    Thanks!
  2. hoochy
    hoochy Need moar cooling
    16 May 2012
    Albeit basic, you can't go far wrong with Google Sketch-up (free version) for starting out with 3D work. It's how I started. You could trying something more advanced like Blender 3d also depending on what you want to do.
    A quick search on google will come up with some links to download both. :thumb: hope this helps
    chrisb2e9 likes this.
  3. lp rob1
    lp rob1 Modder
    14 Jun 2010
    If you do go for Blender, thoroughly read a manual or something on it before you even start it up! I often refer to Wikibooks' Noob to Pro book when I need to figure out a certain command. Blender is vast, complex and unforgiving when it comes to ease of use, but once you have mastered the controls, it becomes exceptionally powerful.
  4. asura
    asura jack of all trades
    22 Apr 2009
    While SketchUp is the opposite, it's basics can be picked up in just a few hours, and most of the advanced commands can be mastered in about a week. However, it's quite limited, and at times limiting.
  5. chrisb2e9
    18 Jun 2007
    Cool thanks guys!
  6. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    What truck are you planning on building / basing it on ( built from up grade parts )?..
