Scratch Build – In Progress Desk Mod: The Blade Desk [5/09- Waterblock update]
Discussion in 'Project Logs' started by Bladesingerz, 14 Dec 2011.
  1. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Hi there! And welcome to my project log of The Blade Desk!
    Current progress:
    More HD pictures on page 3!
    Introduction:
    I've been intrested in pc's for a long time now, but recently I had a budget to buy a new computer! My old pc still had a AMD Dual core and a nvidia 8000 series, it was almost 5 years old and I could only could play most games on minimum.
    Then the day came and I bought my new hardware!
    AMD Phenom II x4 955
    EVGA GTX 550 Ti
    ASRock M3N78D
    G.Skill 8 GB DDR3 1333MHz (Ripjaws)
    Samsung HD103SJ in raid 0
    The hardware was great, becouse I could play all games at high/ultra and even some games like crysis on Ultra, I was very happy with the result. And the intrests in PC's was fully renewed.
    And then I found... Bit-tech o_O *holy sound*, I saw all these great mods and I was facinated and subscribed to allot of great project, I already saw the L3P D3SK a long time ago and found it fantastic, but then I saw some more projects that did some modding to there desk, like the Interior Des(k)ign and the N +H²0, it was fantastic! The idea came to me to do something similar, that idea grew for a few days and decided to just go for it.
    The Blade Desk was born!
    First I started on the wood work, this desk will be in wood simply becouse I'm not good at welding and I also like the feeling of the painted wood.
    Most of the panels were sawn in the store, I made a little drawing and give it to opperator.
    I made some measurements and started sawing.
    Instantly after, a disaster! The hole was just bad, it was to big and couldnt hold the fan. I decided to just buy a hole drill of 115mm, it was an expencife buy but it was an easy fix, I will saw them tomorrow when I have more time.
    The next day I sawed the motherboard holes,
    and the cd player and fan controler hole. I still need to design and make the mounting for the cd player. Also the cd & fan controller holes need to be straight so I will need to file them.
    So far so good, most of the woodwork came allong fine and started looking into my hardware. I went to my old storrage garage and found the 2nd pc I ever used when I was young, I realy had to smile when I looked at the specs, the ram sticks said: 128mb with 133mHz :).
    After a good laugh I started striping down the case so I could use the power button wires and the motherboard mounting plate. It was held with pull nails, I used a drill to drill them out, easy work.
    The following night I painted the mounting panel (now cut in half by a saw). I painted them black and they look pritty descent!
    I realy hoped everything fitted together, and surely enough, it fitted with a minor gap to the side. Since the hole desk will be painted black, that gap will not even be noticed.
    Well thats about all for this past week, I hope i can make some more progress tonight and tomorrow, on fryday I will visit my uncle who will help me glue the desk together!
    ~Bladesingerz
    MrDomRocks likes this.
  2. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Finally an update!
    I've had some help with the wood work of my desk, my uncle (who was a carpenter before he retired) glued my pieces together. this makes is very solid and strong.
    I started drilling the holes for the switches and the fans, I prayed that they would line up correctly with the radiator, and surely enough they did :).
    I thought this was a nice picture, just the desk waiting for all the hardware.
    Some sleeving items and water cooling goodies also arrived that day! I was very excited, this will be my first water cooling project so its pritty simple. I will be only cooling the CPU at this time. But none the less I look forward to the result!
    Fitting the CPU cooler
    My glass was also ready for pickup in my local store, a big thanks to L3P for giving me some advice on the glass and rubber. I had really no experience with glass so the advice helped me to chose a layerd 7mm glass.
    For the fans I saw some good looking enermax fans on the 2001 - A Case Modyssey, I should thank ASPHIAX for giving me some info on them, I realy like the looks on them and there even better than I expected! I cannot even hear them!
    I bought Feser 1 UV Red cooling fluid, I think it looks realy nice!
    I started fitting my hardware in the desk, it alligned almost perfectly.
    After protecting everything with some cooking tissues I started the pump, only to find out I had a leak at the pump, nothing got wet luckely. After some tweaking everything was working fine.
    Next: sleeving and drilling some more holes for the power supply. I'm currious if everything will stay cool enough. Only time will tell!
    Fuganater likes this.
  3. Fuganater
    Fuganater New Member
    6 Jul 2011
    Looking good! +sub
  4. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Thanks! I Hope it all works out! :clap:
    Update time!
    The past 2days I've been painting, sanding, sleeving and soldering (alot)!
    After I made the final drills for the fans and screws I decided to cut the screws to the right size for the radiator. Luckely my dad had a tool for that, so I just had to snap the bolt off, the tool made sure it was a clean cut :)
    Time for the first layer of paint! Primer :)
    After a 24h wait I sanded all the raw parts once more untill I had a realy smooth finish, it realy is silky smouth.
    The next day I went to the paint shop and bought some awesome looking grafite mat black! It is just so good looking, I'm very happy I picked it.
    I painted it twice, each time waiting 12h so I stayed up late that night and painted it again!
    Done! All nicely painted :thumb:
    The next day I started extending my PSU, I big task, the 24pin, the 6pin of the Video card, and the 4pin of the CPU all had to be extended and sleeved, it took me about 6houres to do them all :jawdrop:
    This is a picture when I started the progress.
    After I finished, its still not fully done, but good enough for now. I might be getting some new hardware soon, so I'll need to reposition them anyway. This was the first time I did sleeving.
    I'm glad I sleeved the cables, the result is a much better looking connector :)
    I dicided it was time to saw that fan controller a little shorter, it looks way better that way! I haven't sleeved its cables yet though, since I will be buying some more enermax fans next week.
    To finish the top off, I used this foam tape, its a great anti slip tape.
    An other great property of the tape is that it is a great noice absorber, With that in mind I used some on my pump and in the back of the desk, The HDD's are placed there so they won't even make noice now :) .
    Time to fill it all up again, I also replaced one of the tubes, since it was pushing against my video card.
    And here it is so far! Looks amazing to me, I might be buying some new hardware soon, Looking forward to the research :D
    ~Bladesingerz
  5. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    wow that was fast nice work :clap:
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    so not a bad idea shoving all the gubbings in a desk unit .... ponders....
  7. MrDomRocks
    MrDomRocks Well-Known Member
    5 Sep 2011
    I think Ultimately this kinda idea is what I am going to do once I am in my own home. Planning on having a man cave xD
    Great work!! +1 Rep from me dude!
  8. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Thanks!
    Its alot of work, but if you enjoy the look of your hardware you might aswell do it!
    I currently living at my parents, (I'm still a student at collage) and my desk is right in my bed room, its more of a bro cave though :D
    Thanks so much for the comments so far, it realy makes me proud !:blush:
    theoeyeo likes this.
  9. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Update: Overclocking
    So I know very little about overclocking and I've done some research in the past 2 weeks (while I was waiting for the paint to dry and such :D ). And I just made a good overclock on 4GHz, I'll try to push it harder in the coming days. But since my current motherboard doesn't have any heatpipes for the VRM's it will be tricky to say the least :eek:
    I also did an other Crystal Disk run, and got some good results again :) I'm quite happy with the speed that Raid 0 gives me!
    ~Bladesingerz
  10. theoeyeo
    theoeyeo New Member
    27 Nov 2011
    nice quick and easy build, i like it :thumb:
    how noisy is it? I'm building my own (first) desk pc and I would like to get itcas quiet as possible but wondering whether i will need foam or insulation or it the glass stops the fan noise.
  11. zairs
    zairs New Member
    30 Nov 2010
    that looks so good!
  12. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    I hear a slight buzzing noice, but its not at all enoying.
    The noice comes from the pump wich is already dampend with the anti slip tape, I just taped itright under the pump.
    The fans are realy quiet, they are pritty much silent. My previeus fan was a Cooler Master SickleFlow 120, rated at 19db, and that was realy noicy, the enermax fans are rated at 17db.... So I wold sugest that you research your fans good!
    An other thing is the material of your desk, mineis made from wood (mdf), and wood has the natural quality to absorb sound, if our desk is made out of alluminum or steel then it will make more noice.
    I hope your desk will be as pritty as you hope it will be!
    Thanks!
  13. Gaming_freak_10
    Gaming_freak_10 Active Member
    5 Jun 2010
    that's a nice background on that desktop of yours... where can I find that Bladesingerz? also nice on that desk!
  14. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
  15. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Small update!
    I've been doing some small details to the desk like finishing the dvd-rw player. I've painted over the silver-gray with the same black of my desk, giving it a nice finished look. I also sleeved all the cables of the fan controller and the sata power connector of the dvd player. These are just some small things but they really pay of for the end result.
    These L shaped connectors realy do the trick, there are realy no cables visible. my dad even commented when a walked in the room: "So when are you connecting the dvd-player?" :)
    I've receved a very nice logitech G110 gaming keyboard and a steelseries mouse pad for my birthday, realy happy with it and its a very nice addition to my desk!
    I borrowed my sisters cannon for these shots. I diddn't have a tripot but I placed the cannon on a pc case and a table to give it the stablity for these shots, it worked out quite well! :)
    ~Bladesingerz
  16. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Hi, Did you use glass or clear plastic as your desk top? if you dont mind could you pm me some details? maybe cost to if thats not cheeky
  17. peteski
    peteski long live the pc
    8 Jun 2011
    :jawdrop::jawdrop: thats it :rock: :rock: :rock:
  18. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Send you a pm, hope it helps!
    Thanks! :D
  19. |-Goku-|
    |-Goku-| New Member
    11 Mar 2012
    Would you be able to PM some details as well?
    What kind of glue was used? Did you use any screws at all?
    Looks really nice!
  20. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Sure, always happy to help.
    I used layerd glass for my desk, because acryll or clear plastic is to weak and will scratch in a matter of a days so you realy need glass.
    My glass is layerd out of 3,2,3mm glass layers and unsharpend at all sides (you realy need to unsharpen all te sides, else you will die ;) )
    I payed 60€ (excl tax) for my glass (450mm x 1000mm) at a local glass store, wich was pritty cheap compared to the big hardware stores, they asked 120€. My advice is to look around alot and ask prices, local glass shops are your best bet.
    As for the glue, I used wooden furniture glue, the strongest stuff you can find in a good wood or hardware store :)
    Hope that helps!
