Scratch Build – In Progress DeskJack by Xray : Final Pictures on page 2
Discussion in 'Project Logs' started by cucmag, 30 May 2016.
  1. cucmag
    cucmag What's a Dremel?
    31 May 2014
    Hello Cheapskate :)
    Thanks for you compliment!
    I see that nothing escapes you ... :hehe:
    for the story
    sewing was not provided for at the origin ....
    That's when I saw my imitation leather will take off at the edges I had idea of strengthening all
    but I hold your idea that is very relevant
    thanks again :)
    Hi B negative
    thanks a lot :)
    I hope your stay in Taipei was profitable :thumb:
  2. f001
    f001 What's a Dremel?
    24 Nov 2002
    Looking good, love the Harley theme!
  3. cucmag
    31 May 2014
    Thanks a lot f001 :):):)
  4. cucmag
    31 May 2014
    Hello :)
    a little update today
    this mod work with two graphic card, so we need a SLI bridge
    the red color not fit... so we disassembled the bridge
    we want to use the chrome paint...
    but the result is not up to our expectations :waah:
    ok .... waiting to find another idea, we create a sticker thanks to the plotter
    logo's Harley :)
    we bring together the parts of the kit
    we finally chose to paint the metal parts in black
    it enhances the Harley logo
    the backlight of the SLI bridge do not support our graphics card...
    we had to solder a cable to power the LED circuit
    day...night.... :rolleyes:
    thanks :thumb:
  5. cucmag
    31 May 2014
    Hello :)
    we customized most hardware parts
    it's time to start putting everything in place
    here the plateau receives this little world
    wood that we have covered in leather faux cowhide leather imitation
    we have realized several holes including the establishment of the spacers
    establishment of the motherboard
    LEDs provided with the waterblock are blue....
    blue unbecoming a theme Harley
    we trade against the white
    LED, cable, resistance, soldering station...
    and some sleeving :)
    implementation of waterblock and carenage motherboard
    chipset heatsink is also in place
    we set up the formwork of arrears connectors
    the fairing of the motherboard overwhelmed enough to conceal the sata cable connection
    we position the heatsink mosfets
    all in black
    but we place a polished aluminum plate on top
    holes for the passage of cables powering the motherboard
    we cut small plates to cover these holes
    realization of the passage of each wire
    polishing :)
    fixing at the ATX cable passage
    fixing at the CPU cable passage
    why this round hole....
    for the passage of cables from the hard drive
    and 4 small extra holes to wedge spacers integrating rubber mounts
    good, most of the hardware parts are in place on the tray
    following next time ;)
  6. cucmag
    31 May 2014
    Hello!
    the hardware is quite finished :)
    the following is the decorationfor the desk according to the Harley's theme
    it is not a shield....
    it is a concho!
    in general, it takes place at the saddle of the bike or on the saddlebags
    we put them between watercooling tanks
    as you can see, the right side of the desk is occupied by tanks :)
    they are three tanks XPSC Photon 270 ml
    we continue with some buttons....
    this is for the Power switch
    we let's connect a second for the Reset switch
    another buttons....
    not the same!
    there is to connect some Leds
    five buttons to command the light present on the hardware :baby:
    making a lot of cables to store ... :duh:
    we make another plate to put on the front of the desk, near the tank's tray
    we make some holes on it :D
    some nails...
    oups!!! Xray thinks he is a fakir :D
    go working!!!
    see you soon :)
  7. cucmag
    31 May 2014
    Hello
    we have to built some support on the backstage of the desk
    First with the power supply
    we begin with this plate bended at 90°
    we create the opening for the rear part
    we test the attachment
    locating the fan center
    to create the opening beneath the power supply, corresponding thus to the opening in the desk
    we drill three holes on each side of the power supply for fixing the support in the desk
    even if the media is not seen, we apply a black paint for a better finish ;)
    soon :)
  8. cucmag
    31 May 2014
    hello :)
    we go now to the radiator support
    perfect round but realized with a hole saw :)
    some fans....
    we'll change the label
    road 66 fans!
    another plate...
    some spacers
    we fix the plate
    and we fix the pump on this plate :)
    soon :)
  9. cucmag
    31 May 2014
    the next is to connect the different parts of the hardware :)
    we require wire
    the clamp crimp
    and some sleeving
    the ATX cable is ready
    we do the same with the cpu cable.
    but with the PCIe cable, we change our approach .....
    after having removed plug
    we solder the wires directly on the pcb
    and the cables will be hidden under the fairing against the waterblock
    we have to connect the differents parts of the watercooling :)
    some of them are chromed :)
  10. cucmag
    31 May 2014
    Hello :)
    this time, we have not my disciple Xray on the photos :D
    we finish this mod DeskJack!
    and we present some pictures .... so many pictures we have sorted by category
    the first ones are without lighting ;)
    external view of the Desk and reservoir compartment
  11. cucmag
    31 May 2014
    Hardware Compartment
  12. cucmag
    31 May 2014
    we connect the power and go !!!
    DeskJack on light
  13. cucmag
    31 May 2014
    Zoom on the lights
    the control panel backlight hardware compartment
    RGB LED strip with its own remote control RF
    control over 5 levels independent of each other that can choose what we want to keep the backlight on or off
    here's an animation to better realize
  14. cucmag
    31 May 2014
    Tray in place
    some pictures with the desk top in place
    the opening is filled by a window that have not yet positioned to avoid glare on the photos :)
    I thank all those who have followed closely or by far my workblog
    I hope you liked it
  15. Terrorecosmico
    Terrorecosmico What's a Dremel?
    2 Jun 2016
    beautiful work
  16. cucmag
    31 May 2014
    gracie mille terrorecosmico :)
  17. Seinron
    Seinron What's a Dremel?
    30 Apr 2014
    I love it ! :D
  18. cucmag
    31 May 2014
  19. kim
    kim hardware addict
    10 Jan 2016
    really very beautifull, great skills and creativity, and your pictures as well...hit the road Jack!!!
  20. cucmag
    31 May 2014
    thnaks kim
    I'm glad you like it :) :) :)
