Build Advice Desktop £600 budget for development, visual studio
Discussion in 'Hardware' started by slambittech, 9 Nov 2018.
  1. slambittech
    slambittech Minimodder
    17 Oct 2009
    Hi All,
    Haven't build a PC since last year so don't know what is the latest good spec/value this year.
    Got to build a new pc for development purposes.
    Any recommended builds please.
    Will also be looking at getting 2 monitors for budget of £200-250 (separate from the 600 budget for desktop).
    Budget: £600
    Main uses of intended build: development
    Parts required: everything
    Previous build information (list details of parts): no previous parts can be used
    Monitor resolution: Full HD
    Storage requirements: SSD
    Will you be overclocking: no
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): No real requirements
    Extra information about desired system: Needs to have a good Wifi adapter. (Must I come across seems to be unreliable, so maybe I will go homeplugs method)
    Thanks
  2. GeordieStew
    GeordieStew Minimodder
    7 Oct 2011
    To try to save on some oomph, look to use VS Code :)
  3. slambittech
    17 Oct 2009
    Yeah will also be using that.
  4. RedFlames
    23 Apr 2009
    Ryzen 2200G, 2400G if budget allows
    B450 Board of Choice
    16GB DDR4 of choice [faster the better]
    MX500 or similar SSD [970 EVO or similar if you can blag one cheap in the sales]
    Case/PSU combo of choice
    Should give you change from £600
    EDIT:
    Partpicker linky
  5. slambittech
    17 Oct 2009
    so you wouldn't go i5 route?
  6. RedFlames
    23 Apr 2009
    Not with prices as they are, no.
  7. slambittech
    17 Oct 2009
    is it better to get gpu or intergrated with motherboard?
  8. yuusou
    yuusou Multimodder
    5 Nov 2006
    Are you gonna play games? If so, which?
  9. slambittech
    17 Oct 2009
    Think they play league of legends and maybe some overwatch (Could be wrong so no overwatch)
  10. yuusou
    yuusou Multimodder
    5 Nov 2006
    Then the iGPU on the 2200G/2400G will be enough at 1080p.
  11. slambittech
    17 Oct 2009
    Can you recommended a good wifi adapter?
    Also the ssd M2, are these faster than the normal external ssd ie samsung evo 860 (Thinking in few years they could be used as portable hard drive, if they need to upgrade)
    So heres a quick build, just over budget at £639 but I chose this case because its silent, the pc will be in a sleeping room.
    motherboard
    https://www.amazon.co.uk/ASUS-PRIME...2?ie=UTF8&qid=1541790952&sr=8-2&keywords=B450
    cpu
    https://www.amazon.co.uk/AMD-YD2400...&ie=UTF8&qid=1541791087&sr=1-1&keywords=2400G
    ram
    https://www.amazon.co.uk/Corsair-CM...UTF8&qid=1541791137&sr=1-5&keywords=16GB+DDR4
    ssd m2
    https://www.amazon.co.uk/dp/B07CGGP7SV/ref=twister_B07KB68NR3?_encoding=UTF8&psc=1
    power
    https://www.amazon.co.uk/Corsair-CP...41791533&sr=1-7&keywords=corsair+power+supply
    Case
    https://www.amazon.co.uk/gp/product/B00Q2Z11QE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    What you think?
  12. RedFlames
    23 Apr 2009
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
    Correct, Wifi is from Intel.
    RedFlames likes this.
  14. slambittech
    17 Oct 2009
    Thanks for that, although the case you provide is it dead silent? I've used the fractal one before that I linked with a gaming gpu build 1070 and it is dead silent. Which is why I would buy that one again. Any boards that would fit that case which has Intel wifi? Also the ram I linked I've also used that before, is the Corsair you linked better? Also the power supply, I was advised to only buy Corsair branded?
  15. RedFlames
    23 Apr 2009
    No idea, it came recommended to be by someone else... but cases are often a matter of personal preference.
    Yes. The one I linked. The mATX and full ATX offerings tend not to have Wifi [mainly to keep the cost down and/or tout it as a premium feature and charge more accordingly].
    I've had good experiences with BeQuiet in the past, some recommend Corsair, some recommend the EVGA ones. As long as you don't cheap out you should be ok whichever one you pick. Just try and avoid one with fully captive cables if you can, mainly as it's less **** to have to tidy out of the way.
  16. slambittech
    17 Oct 2009
    Thanks, will consider and read reviews etc and make my decisions.
  17. slambittech
    17 Oct 2009
    I think I am going to go with a combination of your build and the build i created as I like the case, power of the fractal and corsair, the ram of the corsair i liked (I also brought these previously last year for roughly the same price, lol) .
    Going with the ASRock motherboard, cpu and ssd you recommended.
    Now looking at monitors. I have been advised to buy IPS monitors, can you recommend any for around £100. at least 21 inch, not necessary to have VESA but nice to have. (Will be buying 2).
    Been looking at theis: https://www.amazon.co.uk/AOC-Monito...ywords=ips+monitor&refinements=p_36:428446031
    but i understand this is a TN panel.
    Thanks
  18. slambittech
    17 Oct 2009
    also for my santity, am i right in thinking, if i wanted to turn this into a gaming machine I can add a decent gpu and cooling later down the line and it would be comfortable in handling the latest games. Never brought ITX board before.
  19. Vault-Tec
    30 Aug 2015
    As long as you are not using the PCIE slot for anything else then yes. You could easily put in a GPU, as well as a faster CPU or one with more cores (good old AMD to thank for that).
  20. slambittech
    17 Oct 2009
    yeah turns out i might have to do another gaming build so i was thinking maybe the razen 5 2600 with a gti 1070 but everything else like ram, case,motherboard, power should be ok right? would that be comparable with a i7 6700K gti1070 build?
