The main "theme" of the box is to make it dissapear in the livingroom. As you probably can se, the wood where the case is standing i dark/reddish. So I'm thinking it should match quite nicely there with dark outer sides and lighted up inside by 10-20 red LEDs. Don't worry about that. When I put the light to the plasic it burnt a little. But to remove it, you have to put a finger on and wipe it off, so no problem there
looks like he just got a little too close to the heatshrink with the lighter. [EDIT] this is what happens when you don't read the last post in the thread that spilled over to the next page [/EDIT]
I may have a tip for the bubbles... Get a fine needle and carefully pinch a tiny hole in the tint foil and then flatten it again... It may work or it may not, but don't blame me if it screws up everything
Nooo, can't be [edit] He found out himself [edit] I'll try that on my top piece. If it doesn't work, it needed replacement anyways
Made my first acrylic bending today The first try Bad pic, but you get the idea Bent the top and made a hole for the button The finished and mounted power button. Decided to paint the fan aswell, has to be perfect (yea, right!) A Papst 120mm 26db fan, one hell of a thing to dismantle The fan is drying at the moment, so no pics (It would be a shame to disturbe now) Well, it became "later" hehe Painted it red, yup, but only 3 lairs, so it is a dark red. Mounted Ohhh, and a package arrived today Got 20 red LEDs in there Just don't know when I'll get them in there
