Erm, is it actually gonna be possible to mount an Alpha Pal 8045 onto the infinity? Just unpacked it and there seems to be a large number of surface mount components right on the edge of the holes... can i mount my alpha or no?
I put a scythe kamakaze on mine and had to force quite hard to get it to go on the lugs because of the 3 caps below the socket :/ 'doc
MMM so with a little "modding" it might be ok.. anyone actually run a large hole mounted cooler on a DFI? How much force can be put on the surface mounted crap?
