DFI Lanparty 875 Overclocking problem
Discussion in 'Hardware' started by Mark, 8 Aug 2003.
  1. Mark
    Mark What's a Dremel?
    6 Jun 2002
    Hi,
    Ive just installed my new rig, running a DFI lanparty pro875, Corsair Twinx PC4000 1024mb & a P4 2.4ghz(c) 800 FSB. I managed to overclock the cpu to 2.9ghz, then I updated the bios & now I dont seem to be able to overclock, the bios setting stay the same ie 250 x12, but when I boot it says 2.4ghz, windows also reports a speed of 2.4ghz.
    Any help would be appriciated
    Mark
  2. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    Yo Mark,
    More info would be cool :cooldude:
    Like what Bios Version?
    What utility are you using for monitoring your settings?
    Why did you update the Bios?
    BTW - I like the MoBo, I think I'mm gunna get it? would you recommend it ?
    Cheers,
    Mat
  3. Mark
    6 Jun 2002
    Hi mat,
    Got it going now, just re installed the bios. Got the 2.4ghz up to 2.7 stable at the minute. The board seems pretty good so far, no quibbles with it.
    Regards
    Mark
  4. 2t0n1k
    2t0n1k What's a Dremel?
    7 Aug 2003
    Have you tried the chip in another mobo? Maybe it's the limiting factor.. Hey, this forum is chilly:naughty:
