Hardware DFI LANParty DK 790FXB-M3H5 Review
Discussion in 'Article Discussion' started by Tim S, 22 Jul 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. SwiftDestiny101
    SwiftDestiny101 Has a wire neatness fetish...
    23 Apr 2009
    The yellow tbh look a bit naff. I didnt mind the luminous green DFI boards but the yellow makes it look like "My First Motherboard (C) Fisher Price" :p
    PS Page 5 the top power consumption graph subtitle is wrong:
    Power Consumption (Idle)
    Power at wall socket. BIOS Defaults, all onboard hardware enabled. Prime95 Load
    How can it be loaded and idle at the same time :p
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    It's a bit strange that you can't swap out the BIOs on these boards when you could on the AM2+ versions.
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    why no comparions against Intel products?
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I never liked the DFI boards' look to be honest and his one is no exception. Paired with the underwhelming performance I guess I'll just keep my C2D setup a bit longer and wait for i5.
  6. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    Because it's not a CPU review?
  7. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Because its a motherboard review, not a CPU review. If you're looking for CPU upgrade advice we've done loads of reviews recently.
  8. thEcat
    thEcat What's a Dremel?
    1 Dec 2006
  9. yakyb
    10 Oct 2006
    i do understand that but if you look at the Handbrake H.264 Encoding benchmark there is a 5% variation in results based upon what MOBO you use, that could be enough to alter the standings between different chips
    for example a AMD proc on one mobo may perform 2% worse than an Intel Proc but on a different MOBO it would perform 3% better.
    you see the conundrum?
    would be nice for bit-tech to create a database of benchmark results that would be easily comparible accross different systems each time you test a proc you update its bench and the average of all the results is displayed. therefore if you tested said proc on 3 differeent mobos the average of the 3 would be used (or if your clever Top Mean and low) thsi could be done also for GPUs against Proc / Mobo that way if ever we need to compare our old gear we only need to check our products against a relevant benchmark instead of perhaps looking accross 3 differeent review to come up with a conclusion
    for example try comparing a 9800GTX against a 285 using the existing reviews
    (something that is not unreasonable in terms of upgrade path)
  10. Guest-16
    Guest-16 Guest
  11. thEcat
    1 Dec 2006
    Not for sale anywhere, yet, but maybe...
    Guess I'm still haunted by dfi 939 nostalgia :sigh:
  12. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    To be honest, DFI's AMD line of motherboards has tanked. Their last good "enthusiast" motherboard for an AMD CPU would be the NF590-M2R/G. Even then that one had some quirks that made it an "meh' board. When that one died on me 1 year after reciving it i upgraded to the 790FX and while it lasted a short amount of time I was VERY disappointed in the way it performed. So now that that board is dead I am running Intel and the DFI Intel side and I must say that their Intel boards are on the order of magnitudes better than the AMD side.
  13. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    When AMD AM2 range performed so badly for so long DFI kinda jumped ship towards its intel range due to the core duo being such a huge hit.
    DFI should be ashamed by that board. I still love the yellow and black, but they were the brand you expected to be late to the table with there board, but my would it overclock!
  14. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    what wrong with screws on the heatsinks? and whats wrong with clear CMOS at the back?
  15. Horizon
    Horizon Dremel Worthy
    30 May 2008
    well pretty much every motherboard manfufacture, putting very little effort into their amd boards compared to their intels ones. You look at a mainstream intel board and it's more tricked out than an enthusiast amd board
  16. xprodancer
    xprodancer life is like a box of chocolates
    24 Jul 2009
    DFI Lanparty DK 790FXB-M3H5
    i must say im rathewr dissapointed in the board! i have always stuck with AMD cause i prefer it and always will! but this board has to be said is one of the worst yet by DFI they should have spent more time in workin out the kinks instead of rushing it cause its an AMD platform! its so annoying that this happens alot with other brands of boards to!!!! i will keep my out for an upgrade but i will rather find the best one to date than get one of these rushed boards! :wallbash:
  17. Guest-16
    Guest-16 Guest
    Heatsink screws shear off - they are piss poor quality, like always.
    The clear CMOS jumper on the back should be a button for ease of use.
Tags: Add Tags
