Hardware DFI LANParty JR P45 T2RS
Discussion in 'Article Discussion' started by Tim S, 24 Nov 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    My friend bought one of these and he's pretty pleased with it. Cheap for a DFI board. Solid little performer. No complaints.
  3. phuzz
    phuzz This is a title
    28 May 2004
    Pliers. They'll get that screw out. I've even disassembled a harddrive using a pair of pliers to turn the screws when I didn't have the right bit for my screwdriver.
    I've been kind of thinking about an mATX based gaming rig recently, after all, why do you need a full ATX board?
  4. mclintox
    mclintox Eat cheese!
    15 Nov 2008
    The rear I/O seems a bit sparse of features for a board of this price,esp the lack of esata and a few extra usb ports,or am i being a bit picky?
  5. Andreoid
    Andreoid Anfi-tec Staff
    7 Jul 2006
    i love this board :)
    and anfi-tec allready have waterblocks for this :D
  6. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    great as a uATX portable LAN box motherboard. That reset CMOS on the back IO panel shouldn't be too difficult to deal with after all it's not like you'll be reaching round the back of a huge coolermaster or Lian li case in this instance. Reaching round the back is pretty easy with a SFF but what can be more difficult is reaching an internal motherboard jumper as SFF cases often have little wriggly room inside!
  7. Guest-16
    Guest-16 Guest
    But for the cost, why not just have a teeny tiny switch ala Abit used to do??
  8. mascotzel
    mascotzel What's a Dremel?
    2 Feb 2008
    "where the JR P45 doesn't have quite the level of thoughtfulness other DFI products have been given...no Firewire, no eSATA (yet there could easily be)"
    I doesn't seem that you know DFI to well
    I have yet to see eSATA on any DFI board...as for firewire,they have it only on UT ( the most expensive ones) series
    and the CMOS jumper is quite on a lot of their boards
  9. Guest-16
    Guest-16 Guest
    Fair enough. Perhaps I should have said compared to the competition then. I've only ever infrequently looked at high end boards to date.
    eSATA especially - they use a JMicron chipset already for IDE, so one for IDE+2 SATA is little more for a useful extra.
    As I said above, the CMOS jumper should be a very small momentary switch or two position one.
  10. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Way too much money for a mATX board, especially with very little features. No point in this board, really. Crossfire on an mATX board is silly and defeats the purpose of small form factor. Why have mATX if you are going to shove two gfx cards on it. Can get better boards for a lot less. This board seems completely useless to me. Just my two cents. Can anyone really tell me the benefit of this board?
  11. naokaji
    naokaji whatever
    8 Dec 2006
    Well, if you dont run any other cards than Graphicscards then a Matx board is big enough, besides, it saves a lot of space in a regular size case which can be used for WC Gear or you can go for a small and great looking case like Silverstone Crown Series.
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    If anyone really wants eSATA with this board, go hunting for the PCI converter dongley thing that Gigabyte supply with their boards.
    Much more useful than a fixed eSATA on the rear which you'll never use because you can't see back there to fit the cable
  13. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Someone on BT will make a mod for this soon enough.
    Also, have you checked the box, my board came with some elongated jumpers IIRC, certainly usefull if your case is a pain to open like mine.
  14. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I was considering getting this for my SFF gaming rig that I take with lans but I think a single x16 lane with a 4870x2 would probably do me better then two x8 lanes.
  15. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    I thinking about this board the only features missing are the ones I don't use (esata, firewire) and I don't care about onboard sound quality I got a $500 soundcard I've been using
  16. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
  17. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    I have been looking for some time to build a media center for my front room, parhaps this is the right board?
  18. icutebluezone
    6 Aug 2007
    In your review you have: Four DDR2 memory sockets supporting up to 16GB of memory at 667-1,066MHz.
    Its only surepose to be: 8gb total ram.
    Unless you no sumthing dfi dont no. hehehe.
