Hardware DFI LANParty LT X48-T2R
Discussion in 'Article Discussion' started by Tim S, 12 May 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. The boy 4rm oz
    10 Apr 2008
    Why wasn't the board tested with the extra external heatsink that can be attached to the heatsink on the PWMs? I know it wouldn't have made much difference to the tests but it would have been good to see the installation process.
  3. Guest-16
    Guest-16 Guest
    It doesn't come with one.
  4. Andreoid
    Andreoid Anfi-tec Staff
    7 Jul 2006
  5. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    hey, i am sure you just press the power on and reset button on the board to clear bios, my DFI board is like that, reset switch and a power on, hold the two down and it resets the bios
    DFI lanparty UT icfx3200-T2r/g btw
  6. Guest-16
    Guest-16 Guest
    ICFX3200 Cheesecake - that board was pure genius, it's a shame the BIOS is so unoptimised so the memory latency is bad. :-(
  7. Sark.inc
    9 Dec 2007
    yeah, good board it still chugging away with my rooted psu LOL! Causes some voltage problem, killed my last asus board.. So far the bios is corrupt but she still goes! (1 years and a bit now :D) ( god knows how o_O)
    I simply buy them since they are so solid :>
    Been waiting for a board like this to upgrade to! :D
  8. Krikkit
    21 Jan 2003
    I love DFI boards - the new Intel voltage jiggery pokery frightens me though. So many settings! :D
  9. Guest-16
    Guest-16 Guest
    Wait until you see my news post later then...
  10. stoff3r
    stoff3r What's a Dremel?
    20 Nov 2006
    we're closing in on the best ddr2 boards can offer, and soon thay are out of the game :(
    how would a "perfect" ddr2 system look?
    *this motherboard ?
    *OCZ DDR2-1150 Flex II 4096 MB
    *nv 9800 gx2 1GB
    *Intel Core 2 Extreme QX9770 ?
  11. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    If it doesn't support SLi - why 3 PCI-e slots?
    I would have snapped up this board if it was SLi compatible :(
  12. Krikkit
    21 Jan 2003
    It does Crossfire.
  13. p3n
    p3n What's a Dremel?
    31 Jan 2002
    No optical out? Like the layout!
  14. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Got the UT coming thursday :D
  15. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    I think this answers my question over motherboards Bindi! Thanks for the good review!
  16. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Got my UT a few days ago im well happy with it so far no problems and i can run my QX9650 @4GHz 24/7 1.35v just need some better ram :)
  17. Paradigm Shifter
    10 May 2006
    Just ordered the LT this morning. Can't wait...!
  18. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    I should have got the LT and saved me some money as i was going to watercool all the blocks.
  19. Paradigm Shifter
    10 May 2006
    Sorry, thread necro...
    I spent the weekend playing with my DFI, and aside from the woes of getting one of the horrible new batches of Q6600 (L806A) which have terrible VIDs... (1.3125v) it's been quite fun. :)
    I'm slightly puzzled about one thing I've experienced; the X48 chipset is supposed to support 400MHz FSB natively, is it not? I can't get 400MHz FSB stable for love nor money - Windows will just lock up after anything from 30 to 90 minutes of SmallFFTs or OCCT - even with the CPU back at a 6x multi so it's at equivalent stock speed. It's not the RAM either, as I'm running that at it's rated 800MHz, and with the timings slacked right off to eliminate it as a potential cause. I don't think that voltage to the Northbridge should be an issue, given that it's supposed to do 400MHz on the QX9770 chip by default, but I tried increasing it (within reason) to see no effect. Anyone got any ideas?
    ...also, what would you consider a 'safe' maximum voltage for the NB for 24/7 use?
Tags: Add Tags
