Hardware DFI MI P55-T36 mini-ITX motherboard review
Discussion in 'Article Discussion' started by Lizard, 13 Jan 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Elton
    23 Jan 2009
    An awesome motherboard as far as I can see, and once they lower the price...perfect.
    Harkens back to the good old DFI days huh?
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    Lovely little board was surprised by some of the benchmark results
    would love a Little ITX machine but have to be honest would need to be a little less powerful than the one shown something like a 530 would be perfect
  4. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    Seems strange to give it 7/10 for performance when it did so well in the majority of benchmarks to boards nearly twice as much.
    If I was making a small case build I'd love to go for something like this. But I never will. :(
  5. Jipa
    5 Feb 2004
    The problem with really powerful tiny setups are the graphic cards. Even the small HD5750 and GT240 are already one centimeter longer than this. And plug in the 6-pin power and the difference is some 5 centimeters. Really despite the mini-ITX board, a proper gaming computer just won't fit into a tiny cube.
    Good board nonetheless.
  6. Guest-16
    Guest-16 Guest
    Because overclocking is much more limited - in total overclock and in what the BIOS offers that's stable.
    The Gigabyte UD2 and UD3 we tested for CustomPC can also achieve what the more expensive boards can do, but are cheaper than this.
  7. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I have this mobo with i5, 4GB Ram and GTX 295 - perfect little thing! :) I love it!
  8. Redsnake77
    Redsnake77 Useless Idiot
    7 Jun 2009
    Power consumption figures would have been nice to see, but good review otherwise.
  9. Baz
    Baz I work for Corsair
    13 Jan 2005
    MASSIVE gfx card on a tiiinny mobo. Epic.
  10. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    umm, where?
  11. Digi
    23 Nov 2009
    Makes perfect sense then, cheers for clearing that up.
  12. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    Considering this for an HTPC/light gaming build with a dedicated GPU. Any comments on how the on-board audio fared? Not really concerned about storage space as I currently have a dedicated NAS in the works.
  13. Guest-16
    Guest-16 Guest
    Two TWO. :duh:
    :):) No Probs!
  14. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Could you describe the case that you used for testing? I'll have to assume you used a microATX case since there is no such thing as a mini-ITX case that supports a 750W PSU. Mini-ITX boards command a premium for their small size and if you install them in a micro ATX case then you have thrown that premium away. I would have rather seen a test involving the performance that could be squeezed out of scaled components like a picoPSU or other common mini-ITX power supply. Performance per total cubic-inch system size is the how these boards should be measured. IMHO, of course.
    Yes, it is very cool to plug a huge power guzzling graphics card into a tiny mini-ITX board but at the end of the day..it's just stupid.
  15. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    :waah: I WANT IT SO BADLY!
  16. jrs77
    jrs77 Modder
    17 Feb 2006
    This board basically enables us to build something comparable to the Shuttle PCs.
    If you're not into extreme GFX-cards, but pair this board with something more reasonable like a ATi 5770, then you can actually squeeze all the stuff into a box of (30x30x18cm), with watercooling ofc!
    If I wouldn't have a good set of hardware allready, I would definately go for this board.
  17. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    to bad whatever card u throw on that will overtake the board but for a super lean lan machine this would be great
  18. slipperyskip
    slipperyskip Member
    26 Oct 2003
    It would be interesting to adapt this board to the Silverstone SG05 or SG06 mini-ITX case. More interesting (to me) would be a mini-ITX board that supports the on-chip graphics solution of the new Intel CPUs.
  19. jhanlon303
    7 Sep 2006
    Put it in the Lian-Li Q-07 with a mATX PSU or the soon to arrive Q-08 for more ITX room. The lack of video out is probably going to be problematic to most ITX builders who embrace minimal cases.
    we'll see how it builds up
    john
  20. slipperyskip
    slipperyskip Member
    26 Oct 2003
    The 8-pin ATX12V requirement is something that has to be worked around. I'm assuming there is an adapter out there somewhere.
Tags: Add Tags
